Will a D16Y8 engine from an Automatic fit a Manual?
Old May 20, 2008 | 08:43 AM
JLUDE01's Avatar
Default Will a D16Y8 engine from an Automatic fit a Manual?
Will a complete D16Y8 engine from an Automatic 98 civic EX fit a Manual transmission 98 civic EX direct bolt up? If not what other parts would I have to swap to make the automatic tranny engine work on the manual tranny car?
Thanks!
Old May 20, 2008 | 09:51 AM
suspendedHatch's Avatar
Default Re: Will a D16Y8 engine from an Automatic fit a Manual? (JLUDE01)
Usually there is no difference between engines that came with automatic or manual, but in this specific instance for some reason Honda used a different IACV setup. So you can swap your manual trans intake manifold / throttle body / IACV over to the new motor. I believe there is a way to convert the three wire auto IACV to work with a manual ECU but I don't know the details. I'm sure a search would turn something up.
Old May 20, 2008 | 10:01 AM
JLUDE01's Avatar
Default Re: Will a D16Y8 engine from an Automatic fit a Manual? (suspendedHatch)
That is most helpful! My intake Manifold off the manual tranny car is just fine. So long as the block and head are the same I will leave all parts from the manual tranny car intact and just bolt them to the engine from the automatic car.
Are you 100% sure the ECU and wiring harness aren't different between Manual and Automatic?
Thanks. I am searching but there are so many piles of topics on different aspects it's like digging through a haystack after a needle.
- J
Old May 20, 2008 | 10:27 AM
v8 integra's Avatar
i always thought the ecu's were different from auto and manual transmissions...im not 100%
Old May 20, 2008 | 11:34 AM
JLUDE01's Avatar
Default Re: Will a D16Y8 engine from an Automatic fit a Manual? (v8 integra)
Could be but if all I'm doing is swapping the block and head from the auto car into the manual car then the manual car's ECU will work just fine, correct?....assuming the block and head are the same on auto or manual. I'm getting the feeling they are the same, it's only the ECU/and intake manifold that differ?
Old May 20, 2008 | 01:17 PM
Blk00EJ8's Avatar
The harness for the auto is the same as that of the 5 spd, it just has an extra clip and more wires that wouldn't be used. The pinouts are the same.
The ECUs are different, yes, so if you don't have an automatic transmission, you have to run the 5 spd equivalent. An auto ECU will throw codes for not being able to find the auto tranny.
Old May 20, 2008 | 01:22 PM
blk92_d16's Avatar
When it comes down to it (just the basics), the head and block are exactly the same. The supporting items just tend to be a tad different...
Old May 20, 2008 | 01:58 PM
s0flyy56's Avatar
yah i had a Y8 from a auto in my hatch at one point and it was HELLA quick casue you kinda figure it aint beat casue it shifts automaticlly but it idled funny casue the IACV but was a quick motor with nothin else switched over..
i miss my SOHC =[
Old May 20, 2008 | 02:55 PM
93b16dx's Avatar
yeah, now ^that guy knows wat he's talking about.
Old May 20, 2008 | 06:16 PM
JLUDE01's Avatar
Does $750 for a used USDM entire engine sound like an OK deal? It is a VTEC SOHC D16Y8 with 95,000 miles on it at a local salvage yard so no shipping....
Old May 20, 2008 | 07:46 PM
Blk00EJ8's Avatar
Default Re: (JLUDE01)
If it came with absolutely everything that might be an acceptable deal, but if it's just for the motor then that's high.
Old May 21, 2008 | 05:54 AM
JLUDE01's Avatar
Default Re: (Blk00EJ8)
It's a complete motor: Head, block, Intake manifold and all sensors, Exhaust manifold with O2 sensor, timing belt and components all left in tact...it just doesn't have an alternator or AC compressor attached.
Since it's 5 miles from me and has verifyable mileage of 95K (since it's still in the car till I pay for it, then they take it out for me and put it in a crate)
They have a 30 day exchange policy so I have time to run leakdown and compression tests and get it running before it's too late.
Old May 21, 2008 | 06:39 AM
Blk00EJ8's Avatar
Since it's still in the car, are you able to drive it before they remove it? Or is the car totaled or something?
Old May 23, 2008 | 05:17 AM
JLUDE01's Avatar
The car was totalled. And the salvage yard just called and said that motor is no good...somehow it got water damaged? So back to the drawing board.
Old Nov 14, 2014 | 07:32 PM
Jonolver3's Avatar
What other engine harness could I use on a d16y8?
Old Nov 15, 2014 | 01:23 AM
HondaPartsHero's Avatar
Technical Hero
You must list your year make model Ecu etc
tim73
17
Jan 11, 2015 08:08 AM
KingBob26
Oct 11, 2011 07:21 PM
blink_977
Mar 13, 2008 10:02 AM
masterexpert
May 31, 2005 04:13 AM
