front speaker wires ?
Old May 20, 2008 | 07:45 AM
Integra4lyfe069's Avatar
Default front speaker wires ?
when you remove the oem speakers. aftermarket speakers only come with positive and negative wires, do II cut off the plug on the door and just solder the wires accordingly ? positive to negative
Old May 20, 2008 | 08:30 AM
crxma22's Avatar
Default Re: front speaker wires ? (Integra4lyfe069)
plug and play? i'm confused why would you need to solder anywires?
Old May 20, 2008 | 08:39 AM
lsturbo*'s Avatar
Yes you will need to cut of the factory clip but I say use wire nuts instead of soldering, and also leave some wire on the clip so you can always go back to oem. The factory clip has 2 positives/ 2 negatives, just twist them together and then wire nut to your aftermarket speakers.
Old May 20, 2008 | 05:43 PM
Default Re: front speaker wires ? (lsturbo*)
nice, i havnt lookd at it or done it yet, will the positive and negative both be aparent?, also will i have to wire anything else? or do anything special so they get the right frequency or wtf and dont blow ?
Kevs02Accord
Audio / Security / Video
Apr 18, 2009 09:10 AM
Allurian
Aug 8, 2008 09:40 AM
silver hatch
Mar 29, 2005 01:52 PM
95civickid
Mar 25, 2005 07:54 AM
terboracer
11
Jan 15, 2005 09:40 PM
