skunk2 pro3+ cams on a gsr block???
Old May 20, 2008 | 07:02 AM
evildc2's Avatar
Default skunk2 pro3+ cams on a gsr block???
Hey guys I need some wise advice, I have a set of pro3+ cams skunk2
from a trade deal, I got really curious about what kind of power I would get out of them, so I begin to save cash to get pro series valve springs since it seems to be required on this type of cams, I got my self a set of stainless steel supertech valves and titanium retainers, my heads are getting a mild ported and polish
and have the IM ported match with the heads, NOW.......after all that I have a big problem, I was planing to to have my gsr block oversize to 84mm, but now I know that will be impossible to do without $leeving the block
and I am running out of ca$h!!!
my question is .......
will my block run good with this cams if I bore the block to 82mm and just have some type r pistons installed ????
I want to know if this would be a good idea??
also what cc injectors would be good if this was a good set up??
Any positive and experienced feedback will be helpful
Old May 20, 2008 | 07:04 AM
all-mtr-teg's Avatar
Default Re: skunk2 pro3+ cams on a gsr block??? (evildc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evildc2 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys I need some wise advice, I have a set of pro3+ cams skunk2
will my block run good with this cams if I bore the block to 82mm and just have some type r pistons installed ????I want to know if this would be a good idea??
Those cams will be way too big for your setup. Sell them for a good price and pick yourself up some pro 1's
Old May 20, 2008 | 07:14 AM
FST GSR 1's Avatar
Then sell those Ti retainers for some Crower Steel ones !
Old May 20, 2008 | 07:18 AM
evildc2's Avatar
Default Re: skunk2 pro3+ cams on a gsr block??? (all-mtr-teg)
That sounds like a good idea!!!........thanks!!!
Besides getting my block sleeved and over bore
what else would i have to do in order to use this cams???
I am just trying to make some number$
and see what my budget can cover for a setup like this.
Old May 20, 2008 | 07:28 AM
evildc2's Avatar
Default Re: (FST GSR 1)
Isn't steel heavier than titanium ???
Old May 20, 2008 | 07:34 AM
FST GSR 1's Avatar
Ti retainers gall too easily and have been known to fail becuase of it.
If you want to save weight, buy a sawzall.
Old May 20, 2008 | 07:38 AM
pjhatchin's Avatar
Default Re: (evildc2)
First of all you need around 13:1 compression to run pro 3's and anybody with experience with these cams will tell you that you need a much bigger bore which as you know you need to sleeve. As stated before you should sell those cams and go with some pro 1's or save your money and build up a motor that works with the cams.
Old May 20, 2008 | 07:39 AM
evildc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FST GSR 1 &raquo;</TD></TR><TR><TD CLASS="quote">Ti retainers gall too easily and have been known to fail becuase of it.
If you want to save weight, buy a sawzall. </TD></TR></TABLE>
LOL
Thanks bro !!!
Old May 20, 2008 | 07:48 AM
FST GSR 1's Avatar
Welcome. But I am serious...My DC2 is 2224 right now full interior(leather back seats even), I am looking to shave another 24lbs. now lol. I'll find it somewhere.
Old May 20, 2008 | 07:50 AM
evildc2's Avatar
Default Re: (pjhatchin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pjhatchin &raquo;</TD></TR><TR><TD CLASS="quote">First of all you need around 13:1 compression to run pro 3's and anybody with experience with these cams will tell you that you need a much bigger bore which as you know you need to sleeve. As stated before you should sell those cams and go with some pro 1's or save your money and build up a motor that works with the cams.</TD></TR></TABLE>
I think this answer al lot of my questions
thanks bro!!!
Old May 20, 2008 | 07:54 AM
evildc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FST GSR 1 &raquo;</TD></TR><TR><TD CLASS="quote">Welcome. But I am serious...My DC2 is 2224 right now full interior(leather back seats even), I am looking to shave another 24lbs. now lol. I'll find it somewhere.</TD></TR></TABLE>
Make it convertible!!! LOL
Old May 20, 2008 | 08:03 AM
2fastGSR's Avatar
King of the One Liners
I'm not sure if the valve reliefs on a stock type R piston would be deep enough to run the cam anyways.
Even forgetting the displacement/ compression requirements.
Stock pistons , regardless of what motor ( itr, ctr, type s) dont have deep valve reliefs meant for big cams
Old May 20, 2008 | 08:13 AM
evildc2's Avatar
Default Re: (2fastGSR)
Good point
I was hoping to be able to use them but I gess I'll have to give up on that idea
GsrIntegra789
Jan 27, 2008 02:29 PM
SEXY TIME!
Sep 2, 2006 07:45 PM
0bd1_Kanobe
Apr 5, 2004 12:03 PM
Modifiedinteg
Oct 13, 2003 05:02 PM
STEV3-O
Jun 7, 2003 11:44 AM
