Parting out OBD-1 LS Blocks in NJ
Old May 20, 2008 | 07:00 AM
slacks's Avatar
Default Parting out OBD-1 LS Blocks in NJ
PRICES LOWERED AND STILL BEST OFFER!! NEED TO SELL TO START NEW BUILD!
I ran out of money to rebuild my LS motor so parting it out the best as possible.
If anything you need is not listed let me know!
EVERYTHING is best offer first!
B18b block - has score on cyl 4 - sold to f22beast
LS Valve Cover (pretty minty) - $40obo
b18a block - freshly honed and hot tanked - 180obo
-Injectors - best offer
-anything else you need let me know
Harness - only cut at the distributor area - 30obo
B18a rods and pistons- pressed with ARP rod bolts - 100obo
b18b rods and pistons - one piston is busted - 30obo
NEW OEM b18a/b rings - 70obo
untapped LS oil pan w/ gasket - 50obo
windage tray - 15 obo
oil pickup - 20 obo
Oil Pump - $30 obo
LS flywheel - needs some resurfacing - 35obo
Driver Side B Series Mount - $20
obd1 dizzy - pigtails are cut - 30obo
Some throttle body - $20obo
P/S Bracket (I think) $10 - I have two of these
P06 ECU with chip kit form phearable.net to run b18b - 55obo (partially finished and not tested)
Timing belt and T-belt Covers (make offers)
Pictures of everything are available upon request.
IM me on aim at Styraphone or email me at ninjabem@gmail.com
Modified by slacks at 9:56 PM 8/23/2008
Old May 25, 2008 | 02:10 PM
B18PwdCivic's Avatar
Default Re: Parting out OBD-1 LS Blocks in NJ (slacks)
GOT A GOOD LS CRANK??
Old May 25, 2008 | 02:21 PM
slacks's Avatar
Default Re: Parting out OBD-1 LS Blocks in NJ (B18PwdCivic)
^ pm sent
Old May 27, 2008 | 06:13 PM
gourley's Avatar
abcdefg for a good dude!!
Old May 27, 2008 | 06:33 PM
B16aCRXSi's Avatar
you got the oil pressure sendin unit and half shaft bracket? let me know
Old May 29, 2008 | 04:42 PM
slacks's Avatar
Default Re: Parting out OBD-1 LS Blocks in NJ (B16aCRXSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">you got the oil pressure sendin unit and half shaft bracket? let me know</TD></TR></TABLE>
pm'd and updated with pictures!
Old May 29, 2008 | 04:51 PM
f22beast's Avatar
Will you ship the B18B Block. I PMed you. I live in Northeast PA
Old May 29, 2008 | 05:43 PM
slacks's Avatar
Default Re: Parting out OBD-1 LS Blocks in NJ (f22beast)
pm'd back!
Old May 29, 2008 | 08:39 PM
gourley's Avatar
my homie my homie my homie! the gyms closed!!
Old May 29, 2008 | 09:03 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Old May 30, 2008 | 09:13 PM
geebs's Avatar
Default Re: Parting out OBD-1 LS Blocks in NJ (_HANS)
that b18b block.. is that score horrible? will can i bore it .5mm to get rid of it? does it have a crank, main caps?
Old May 31, 2008 | 04:24 PM
f22beast's Avatar
The block was in good condition. That score can be honed out. But since im getting it sleeved by Benson it won't matter.
Slacks does good business. Up front guy.
Old May 31, 2008 | 04:38 PM
slacks's Avatar
thanks man
good luck with the build too!
Old Jun 1, 2008 | 06:03 AM
gourley's Avatar
your the man!!!
Old Jun 2, 2008 | 07:33 PM
slacks's Avatar
Old Jun 6, 2008 | 09:02 PM
kojack_0's Avatar
bump for a crazy friend.
Old Jun 11, 2008 | 08:03 AM
slacks's Avatar
Default Re: Parting out OBD-1 LS Blocks in NJ (kojack_0)
lowballers welcome
Old Jun 13, 2008 | 02:33 PM
slacks's Avatar
more stuff!!!!!
Old Jun 15, 2008 | 08:13 PM
slacks's Avatar
Old Jun 19, 2008 | 08:38 AM
slacks's Avatar
Old Jun 19, 2008 | 09:21 PM
slacks's Avatar
Old Jun 23, 2008 | 06:55 AM
slacks's Avatar
Old Jun 23, 2008 | 09:46 PM
slacks's Avatar
lowballers please come in!
Old Jun 25, 2008 | 01:20 PM
slacks's Avatar
Old Jun 27, 2008 | 07:48 AM
slacks's Avatar
ttt!
