99 Accord - Changing the master and slave clyinder
Old May 20, 2008 | 04:43 AM
ZMan3000's Avatar
Default 99 Accord - Changing the master and slave clyinder
Anybody knows how to insert that pin back into the groove on the new master cylinder. I replace my master because it was leaking. Only thing is I can't get that pin to go in for the clutch line. I was wondering if there is any tool or trick to it.
I had the same problem with the slave. The slave was even worse. It had a small pin that was almost impossible to get out. I had to cut the old one to remove the clutch line. I tried for hour to put that small pin back in but no luck. After that I just used a cotter pin on the slave. Seems like its holding up good. I actually lost the pin in the process of trying to push it in, that's why I had to use a cotter pin.
If any body has any ideas on pushing this thing in, I really appreciate it.
Many thanks.
Old May 21, 2008 | 11:53 AM
ZMan3000's Avatar
Default Re: 99 Accord - Changing the master and slave clyinder (ZMan3000)
Nobody here has changed the slave and the master cylinder on a 1998 to 2002 Accord? Please help.
ns-export
Oct 22, 2017 08:45 AM
westcoastaccord
Jun 24, 2016 12:34 PM
03djmAccrd
Jul 8, 2010 01:37 AM
steerh67
Apr 12, 2007 06:31 PM
AFAccord
Jan 19, 2006 06:47 AM
