O2 bung O2 sensor question
Is the O2 bung just a hole in your cat/header? Is it threaded or anything? What keeps the O2 sensor in there?
I have two O2 sensors on my GSR, and I'm planning on replacing my header/exhaust. I want to plan accordingly but I'm worried about my O2 sensors ruining my plans. Are there any work arounds for O2 sensors?
I will assume that you have one before and after the cat.
The bungs are threaded. Usually, aftermarket headers should already have a bung welded on. As for exhausts, catbacks would assume that you would have a bung on the cat. Although, most universal and hi-flow cats do not come with a bung welded on. An exhaust shop should be able to weld one on (if there isn't one on the cat) for you relatively easy.
aaronblake9898
Feb 13, 2004 03:55 PM
