engine bay
Old May 19, 2008 | 07:30 PM
cb hatch's Avatar
Default engine bay
Well i just finished up the last of my bodywork and paint , installed my Da center console , installed my stereo . Now what id really like to do is clean the engine bay. Anyone have any tips on how to go about it ? Never done it before so what kind of product should I use etc.. Any help would be appreciated
Old May 19, 2008 | 07:32 PM
ha...tch's Avatar
its a lot easier with the motor out of the car. more room to work.
Old May 19, 2008 | 07:40 PM
cb hatch's Avatar
Default Re: (ha...tch)
Isnt there products that you can spray and then hose down ?? Like i said ive never done it before , correct me if im wrong. If there is , does anything have to be covered , like air box etc....??
Old May 19, 2008 | 08:20 PM
Fuzzy Rhubarb's Avatar
Default Re: (cb hatch)
citrus engine brite
cover sensitive stuffs, spray on, let sit, lather, rinse, repeat
Old May 20, 2008 | 03:51 AM
gursh d's Avatar
Default Re: engine bay (cb hatch)
simple green auto degreaser to clean the engine bay.
And if you want to clean up all the wiring in the engine bay for a cleaner look, you can do a wire tuck. Check the FAQ.
Old May 20, 2008 | 03:57 AM
newby_j's Avatar
Needs More Cowbell
Default Re: engine bay (gursh d)
put a plastic bag over your distributor and air filter and other things that you don't want wet. spray with simple green wait 5 mins scrub with a soft brush spray with simple green again scrub again spray off with the hose be careful around the spark plug area as the water likes to get down by the plugs and cause a miss fire. if that happens, take out the plug wires from the plugs and spray it out with a air hose
trepteg
Mar 31, 2008 08:02 AM
beaterman
May 6, 2003 09:19 AM
ekfever
36
Mar 12, 2003 06:17 PM
Si Arn
22
Mar 5, 2003 01:08 PM
SagaGSR
Aug 23, 2001 10:25 AM
