Si radiator in a crx
i wanna but an Si radiator off a 96 ek coupe....on to my 90 Si crx.....wats da best way to mount it.....n am not talking about a mickey mouse job n slap on zip ties............
I doubt it will mount correctly, although I can't speak from experience. I did put a 93 Integra radiator in my 91 STD hatch though, stock radiator mounts and all, fits perfect!
First off, when was there every a SI in 96? And second for you to use a EK (or EG) rad you will either have to make some custom mounts, use a aftermarket crossmember or put a gangsta lean on it. I have a EK hatch radiator in my crx, I had to use a Innovative x-member and there radiator mount.
well is the problem the height or is it that there is no tab to mount it on? because you can add the tabs to the front core pretty easily... just go cut some out of a junk yard and then tac em into yours...
i was talking about an ek coupe si.........n i got the innovate cross member.....so am gonna use the rubber brakets off some radiator than i found in a legend..since there big..am gonna weld them on n cut off ca original radiator brakets off...n fit it on my cross mem.....
thankx........
thankx........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_jdm_nerd »</TD></TR><TR><TD CLASS="quote">i was talking about an ek coupe si.
That model only existed in 1999 and 2000
SINISTR
Jun 19, 2006 05:57 AM
