ek4 gsr 1/4time?
Just wondering what times i'll be expecting from my 96 civic cx hatch with a full jdm gsr swap.(gsr block head and ecu).
People's been telling me i'll be running 15.2-15.4. So i'm not sure.
I'm going to be running my car in a month but i would like to have some kind of idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project_EK »</TD></TR><TR><TD CLASS="quote">i did 14.2 with a bone stock usdm gsr in my ek (on BFG drag radials) and 14.4 on street tires</TD></TR></TABLE>
What size were those BFG's?
Practice makes perfect at the track man. I'd say around 15.0-15.3.
GL
GL
Makes me feel like a moron. I did 14.2 with cams, different pistons, springs, valves, "tuned", etc.. I must suck. What size tires/rims you on? What was your trap speed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX »</TD></TR><TR><TD CLASS="quote">
GL</TD></TR></TABLE>
205/50/15's.. I was going those ET's at 95MPH sometimes 96MPH! the motor was very healthy. and u should def at least be in the mid 14s... stock integra gsr's do 14.9-15.0's with a good driver! launch high (6k rpm) & feather the clutch and u'll cut some good 60's
good luck!!
practice makes "good"
good luck!!
what do you mean by feather the clutch?
I ran 14.6 with gsr in ek with exhaust, intake, flywheel and chipped ecu
I need to lower my 60' times. they were around 2.4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victoriasamantha »</TD></TR><TR><TD CLASS="quote">what do you mean by feather the clutch?
I need to lower my 60' times. they were around 2.4</TD></TR></TABLE>
feather means to lay off of it easily, so you engage gradually rather than popping the clutch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinturbosupra123 »</TD></TR><TR><TD CLASS="quote">i say high 15s to low 14s</TD></TR></TABLE>
so 14.0-15.9? very descriptive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black36 »</TD></TR><TR><TD CLASS="quote">pull a 14.8 95mph in a rex with bfg drag @ lacr... my boy did a 14.5 with his itr</TD></TR></TABLE>
A "rex" isn't an EG...
either is an ITR...
either is an ITR...
That is a TWO second range you gave there.
That is like saying a twin turbo Supra will run anywhere from mid 13s to mid 15s
