manual transmission
Old May 19, 2008 | 01:58 PM
bugsy22's Avatar
Default manual transmission
i got a 93 accord lx 5 speed my problem is sometimes its hard to shift into 3rd gear i have to let the rpms die down and then shift it because if i dont it grinds the gears can anyone help thanks
Old May 21, 2008 | 06:25 PM
cbaber's Avatar
It's probably your synchro. You can probably just find another transmission for your car for cheaper than it would be to fix it.
Old May 22, 2008 | 06:11 AM
hatchling37's Avatar
Default Re: (cbaber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbaber &raquo;</TD></TR><TR><TD CLASS="quote">It's probably your synchro. You can probably just find another transmission for your car for cheaper than it would be to fix it. </TD></TR></TABLE>
Most definitely the synchro, or more specifically, the dog teeth are worn out. A synchro set will probably run you about $200 if you buy it online, plus the labor to tear it down and install it. Is this something you're capable of doing? If not, you might just look for a new tranny.
Old May 22, 2008 | 09:44 PM
Mr.CrackHead's Avatar
+1 on synchro
Old May 23, 2008 | 08:10 PM
bugsy22's Avatar
Default Re: (hatchling37)
do you know where i could get aset of synchros at ive tried to look them up but cant find any thin g about it
Old May 25, 2008 | 01:10 PM
bosco500's Avatar
Default Re: (bugsy22)
gear-speed.com has 3,4,5 carbon coated sets for $150 shipped.
rumdig2001
Jan 24, 2006 10:45 AM
samba
Jan 31, 2005 12:59 PM
Browneye
Oct 10, 2004 05:14 PM
jerrywidening
11
Jan 15, 2004 10:29 PM
