Video (murcielago)
that race was local around here. There's actually a few of them online. The owner of the Lamo is some 27 year old guy. He got the first one in the US and its the same yellow one featured in Motor Trend, etc... I see him all the time crusing around my area with some F40 next to him. The owners are pretty cool and will normally take off for people.
Yeah to race a Lambo is a awesome thing. I speak from experiance with a VTTT.
Too bad I broke my blower belt about 15min before I raced it.
thats right! I've seen a few of them around here (white, yellow, red. Only seen 1 VTTT though, the others were just VT's) however I'm normally on the other side of the road, etc... However this time one (of course it had to be the VTTT) pulled right up next to me by my house at a light! And the driver just sat their and rev'd his engine at me. However I couldn't do crap because I just broke my blower belt like 10min before that and had the next belt in the back seat to put in when I got to my house!! What luck I swear. I swear I cried when he pulled up next to me. It just wasn't fair.
But yea is was a real VTTT with the VTTT writing going across the sides of the car. The VTTT stands for Vicious Traction Twin Turbo!!!!!!!! That baby hauls ***.
Info on this car:
"Only a very few Lamborghini Diablo VT's were converted to Twin Turbo versions, actual numbers are not available but most sources state only 6 have been built.
These cars are currently very expensive and a rather rare find if you would like to purchase one. Recently, Platinum Motors Ca. had one for sale, finished in black over a tan interior with red piping.
The original price was about $ 500.000, but for this amount of money you got between 600 and 750 Bhp depending on Turbo pressure, with a 0 to 60 mph time of only 3.2 seconds ! A very nice feature was a dash-mounted switch with three settings, one for valet use which limited the engine to about 3500 rpm, the second setting controlled a 6 psi boost delivering around 600 Bhp while the third one was a full 750 Bhp with 9 psi turbo pressure. All this led to a top speed of a healthy 358 Km/h. (222 Mph).
Twin blueprinted, water cooled, Garret T4 turbo's were installed with electronically controlled waste gates, custom built intercoolers, competition type valves with race-type guides and polished cylinder heads. A custom twin-plate clutch in kevlar to cope with the extra torque, a new short ratio gearbox to improve acceleration, and reprogrammed electronic fuel injection system, also the brakes were upgraded with cross drilled and ventilated discs using carbon fibre brake pads.
With all this power behind the drivers back, luckily the air conditioning system was upgraded too, just to keep your head cool enough to enjoy the brutal force of this unique kind of car.
The standard Diablo wheels became chromed and the bolts used for the three piece wheels were gold plated, just to get that extra touch when you park this exotic in the California sun.
One of the Twin Turbo's built was in fact a 1996 Diablo VT Roadster, the only Twin Turbo Roadster in the world until Gemballa made one too, this special VTTT Roadster was finished in red with a white leather interior, it was for sale at the beginning of 1999 at Platinum Motors.
A second hand Diablo VTTT will still cost about $ 380,000, if you can find one, because as far as I know only seven original VTTT's were ever made.
The story behind the creation of the Diablo VTTT's is quite interesting, they wanted to bore the standard 5.6-Liter out to a 7.4 Liter unit, but Automobili Lamborghini SpA didn't advice this move, it would be more feasible to use the 7.0 or even the 8.0 Liter marine engine from Lamborghini. After close calculation this engine would pump out 640 Bhp with stock compression, but by installing two turbo's and boosting the compression, an easy 1170 Bhp was possible on dyno-testing, unfortunately this much power and torque would rip the Visco Coupling to pieces, so avoiding to rebuild a stronger coupling system, they settled for the standard engine and ended up with about 758 Bhp on the wheel dyno, unfortunately since the front axle drive was removed when testing the engine, about 20 percent would be lost driving the front wheels too, but still a healthy 600 Bhp would be available to the fortunate driver.
Another 'tuning' option was available for the early Diablo's, Scott Ponsolle still had a few Stage II kits available which made the engine pump out about 100 Bhp more than normal, but this package didn't work on the later SE or SV type, only the 2wd Diablo and the VT. This 'factory official' package included special SV cam's, re-programmed ECM's, Micron air filters and modified spark plugs, and best of all, these kits were factory approved because they were probably left-over units from an earlier attempt from Automobili Lamborghini SpA to enter racing, this means no warranty issues resulted from their installation in a Diablo still under factory warranty.
Later a lucky owner had his Diablo VT converted into a Twin Turbo car much in the same way as the original VTTT's, but some major differences were apparent, the engine hood was taken from the SV model and the cylinder heads were heavily modified.
Probably the most important difference however was the fact that this 'seventh' VTTT was not an original Platinum Motors VTTT, the six VTTT's were all built under contract for Platinum Motors, this seventh car wasn't ... but it still looks great and with about 850 Bhp (that's what the license plate says) is should have enough power to outperform the Diablo 6.0 VT."
The VTTT makes the new Lambo look like child's play. 0-60 in 3.2 on low boost and est. quarter mile of 10.2 on street tires with low boost setting!!!!!! OMG!!!
TECHNICAL SPECIFICATIONS
Lamborghini Diablo VTTT
ENGINE
Type V12
Mid-longitudinal
Aluminum block and heads
chain driven DOHC per bank
Valves 4 per cylinder
Capacity 5,707cc
Bore/Stroke 87mm x 80mm
Compression 10:1
Turbos 2 Garret T4 turbos
Fuel System Weber-Marelli electronic port fuel injection
Max power 600bhp @ 6,800rpm (low boost setting)
Max power 752bhp @ 6,800rpm (high boost setting)
DRIVETRAIN
Transmission Four wheel drive
Gearbox 5-speed + reverse
Transfer-gear Ratio 1.59:1
Final-drive Ratio 2.41:1, limited slip
Clutch Dry single plate 10"
Gear Ratios
1st 1:2.12 - 65.5 mph
2nd 1:1.52 - 89 mph
3rd 1:1.13 - 121 mph
4th 1:0.89 - 154 mph
5th 1:0.68 - 202 mph
Reverse 1:2.31 - 59 mph
Differential Central - Viscous Coupling
Front Bevel Gear Type - Limited Slip 25% - Ratio 1:2.81
Rear Bevel Gear Type - Limited Slip 45% - Ratio 1:2.41
STRUCTURE
Chassis Steel-tubing space frame
Body Aluminum alloy, carbon fibre and fibreglass reinforced plastic
Wheels O.Z. Racing 3-piece, cast aluminum hub with forged aluminum rim
- front 8.5 x 17 inches
- rear 13 x 17 inches
Front Tires 245/40ZR-17 Pirelli P Zero
Rear Tires 335/35ZR-17 Pirelli P Zero
SUSPENSION
Front Independent unequal length control arms, coil springs, anti-roll bar.
Rear Independent unequal length control arms, 2 coil shock units, anti-roll bar.
BRAKES
Type Vacuum power assisted
Front 12.6 in. ventilated discs
Rear 12.2 in. ventilated discs
DIMENSIONS
Wheelbase 2674.4 mm / 104.3 in
Overall Length 4502.6 mm / 175.6 in
Overall Width 2059 mm / 80.3 in
Overall Height 1115.4 mm / 43.5 in
Front Track 1553.8 mm / 60.6 in
Rear Track 1656.4 mm / 64.6
Ground Clearance 143 mm 5.5 in
Weight 1701 kg / 3750 lb
Distribution
Front/Rear
40/60
Fuel Tank 26.4 U.S. Gallons
PERFORMANCE
Top speed - 600bhp 222mph (low boost setting)
Top speed - 752bhp 255mph (high boost setting)
0-60mph - 3.2 (low boost setting)
1/4mile - 10.2 (low boost setting)
[Modified by Rboosted717, 11:47 AM 7/15/2002]
Info on this car:
ENGINE
Type V12
Mid-longitudinal
Capacity 5,707cc
Compression 10:1
DRIVETRAIN
Gear Ratios
2nd 1:1.52 - 89 mph
STRUCTURE
SUSPENSION
BRAKES
DIMENSIONS
Distribution
Front/Rear
40/60
PERFORMANCE
The video is horrible. It's out of focus and dark. Before you even know what is going on, the video is over.
Download it if you want to see cars accelerating on the highway and then slowing down.
