MEATBALL MECHANI SWAPPED MY HEAD NOW MY ENGINE LIGHT IS ON AND D4 FLASHES CONSTANTLY
Old May 19, 2008 | 12:14 PM
ottoman213@hotmail.com's Avatar
Default someone please help? swapped head in my 93 accord now im worried if it was worth it
93 honda accord 2.2l 4cyl usa/ex......timming belt broke.....bent exhaust valve on #1 cylinder....so i replaced whole head, gaskets,water pump,timming components,...cylinder walls looked in good shape....now....the head i received was listed as a replacement for my year and model.f22a sohc ,but, was slightly different when i got it as far as where the distributor coil mounts and a small piece of the upper timming belt cover. since i got it back three days ago my engine light is on and my d4 flashes constantly. on the highway when i get up to about 60 mph it to seems rough. some things i might mention to help better. i drove the car once a day when the valve was bent. only two miles a day to work and home i would put it in neutral when i would stop at stop sighns or red lights when i could avoid the motor fighting itself due to only running on three pistons..... sorry if my post are lenghthy..and im posting this here because i think one of you can help me so instead of throwing parts at my car im trying to throw as much info at any one who can throw info back... sorry in advance if i mispelled, mi prnounced or confused any one just asking for some input here
Modified by ottoman213@hotmail.com at 12:25 PM 5/20/2008
Modified by ottoman213@hotmail.com at 12:27 PM 5/20/2008
Old May 19, 2008 | 02:53 PM
hondadude's Avatar
Default Re: MEATBALL MECHANI SWAPPED MY HEAD NOW MY ENGINE LIGHT IS ON AND D4 FLASHES CONSTANTLY (ottoman213
Do you have cliff notes of what you are really asking?
There is no need to SHOUT at us.
Old May 20, 2008 | 09:13 AM
whats with the attitude just because my cap locks are on doesn't mean im shouting unless i DO THIS!!! , by the way i if you still need an explanation its because my eyes get sore because i have a really good graphics card in my pc and small print makes my eyes sore...... any way you need cliff notes...........93 honda accord 2.2l 4cyl usa/ex......timming belt broke.....bent exhaust valve on #1 cylinder....so i replaced whole head, gaskets,water pump,timming components,...cylinder walls looked in good shape....now....the head i received was listed as a replacement for my year and model.f22a sohc ,but, was slightly different when i got it as far as where the distributor coil mounts and a small piece of the upper timming belt cover. since i got it back three days ago my engine light is on and my d4 flashes constantly. on the highway when i get up to about 60 mph it to seems rough. some things i might mention to help better. i drove the car once a day when the valve was bent. only two miles a day to work and home i would put it in neutral when i would stop at stop sighns or red lights when i could avoid the motor fighting itself due to only running on three pistons..... sorry if my post are lenghthy..and im posting this here because i think one of you can help me so instead of throwing parts at my car im trying to throw as much info at any one who can throw info back... sorry in advance if i mispelled, mi prnounced or confused any one just asking for some input here
Old May 20, 2008 | 09:18 AM
oh forgot to mention i cannot get codes from autozon because my car is a 93 and i do not know where the data connector is or wich pins to jump like i could do in my chevy but never had this prob so i never had to search for codes yet in this car. maybe if i knew how to pull the codes i could put them out there for better feed back
Old May 20, 2008 | 09:21 AM
TouringAccord's Avatar
H-T Order of Merit
check in the FAQ for how to check the codes.
Old May 20, 2008 | 10:10 AM
do you think the difference ,if any, in the head would throw the computer off i figuired if the head is incompatable it wouldnt run at all.
Old May 20, 2008 | 11:54 AM
Mr Yamada's Avatar
Perhaps check the wiring harness that runs under the distributor, maybe some thing was left unplugged, or wires damaged.
I cannot think of any reason the head change would cause the D4 light to turn on; meaning of course that the TCU has a code stored.
To check the codes jumper the blue two pin connector located at the passenger side kick panel and turn on the key.
Watch the CEL and D4 light for pulses.
A long flash is equal to a ten count and a short flash is equal to a single digit count.
miaozer
Feb 4, 2015 06:32 AM
gummer88
Apr 23, 2013 04:53 PM
hotinteggy
May 26, 2006 02:27 PM
Scotty Dosent Know
Oct 6, 2005 04:49 PM
