Suspension question
New to the site! I have a 01 Civic EX. I have recently replace the springs with Dropzones. I have noticed that there is a 1/2" difference in the ride height on the the front from the left side to the right side. Was wonder what might cause this. I did everything the same on either side????? Also was unable remove the rear bolt on either side in the rear under the car to remove the suspension. Used impact, breaker bar with a pipe on it. cant get the bolt to budge! any suggestions.
Modified by bduncan at 10:55 AM 5/19/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bduncan »</TD></TR><TR><TD CLASS="quote">I have noticed that there is a 1/2" difference in the ride height on the the front from the left side to the right side.</TD></TR></TABLE>
that is normal for our cars. driver side is heavier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bduncan »</TD></TR><TR><TD CLASS="quote">Also was unable remove the rear bolt on either side in the rear under the car to remove the suspension. Used impact, breaker bar with a pipe on it. cant get the bolt to budge! any suggestions.</TD></TR></TABLE>
I got it off but I don't really got much of a tip for that.. bump
J.nguyen
Suspension & Brakes
Sep 11, 2006 12:29 PM
