Which Radiator? (URGENT)
Old May 19, 2008 | 09:12 AM
tpeezy's Avatar
Default Which Radiator? (URGENT)
I need to replace my radiator and I'm unsure as to which one I need. I have a 92 Civic CX but it has a 94 B18C1(GSR) motor in there. Do I use the radiator from a Honda Civic or Acura Integra?
Thanks in advance,
Tom
Old May 19, 2008 | 10:00 AM
Speed_1's Avatar
you would use the one for your car. in your case a 92-95 civic. there are some options you could do like an aluminum radiator, or if you dont have A/C any longer you could put in a wide radiator.
Old May 19, 2008 | 10:25 AM
Blk00EJ8's Avatar
Default Re: (Speed_1)
You can get a half width Civic dual core radiator from an EX and that would be sufficient with the GSR. If you decide to go with a full width, you will need to have additional brackets welded on. The half width will drop right in though. OEM is fine, but aluminum aftermarket also works.
Old May 19, 2008 | 12:45 PM
blk92_d16's Avatar
Get the '92 Civic half rad, but get the dual core.
Old May 19, 2008 | 12:46 PM
riceburnerryan's Avatar
if your strapped for cash use a stock EG radiator
Old May 19, 2008 | 03:04 PM
tpeezy's Avatar
Default Re: (riceburnerryan)
Thanks guys! I got lucky and picked up a Koyo high performance radiator from the junk yard for $65. I guess someone wrecked their built Civic recently, heh.
Old May 19, 2008 | 05:58 PM
blk92_d16's Avatar
Lucky you! Good find.
gsxr1k05
Sep 14, 2010 06:32 PM
Varano44
Sep 17, 2008 05:13 AM
tpeezy
May 21, 2008 08:25 AM
Stop the Beast
12
Mar 14, 2002 12:19 PM
