STORE BOUGHT HONE
Old May 19, 2008 | 08:52 AM
nate24740's Avatar
Default STORE BOUGHT HONE
DO THE STORE BOUGHT CYLINDER HONES WORK
Old May 19, 2008 | 09:16 AM
superfast666's Avatar
Default Re: STORE BOUGHT HONE (nate24740)
if u know what your doing
Old May 19, 2008 | 10:33 AM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate24740 &raquo;</TD></TR><TR><TD CLASS="quote">DO THE STORE BOUGHT CYLINDER HONES WORK</TD></TR></TABLE> Depends on the store. The ones from the Sunnen or Goodson store work well.
Old May 19, 2008 | 09:22 PM
wed3k's Avatar
a guy at the machine shop that i work at apparently can hand-hone a block down to the thousandth
's.
Old May 20, 2008 | 04:09 AM
nate24740's Avatar
thank that helps
Old May 20, 2008 | 10:44 AM
sleepencivic's Avatar
I HAVE USED THE DINGLE BALL TYPE WITH GOOD RESULTS...on many stock bore re-builds..sorry for the caps
Old May 20, 2008 | 11:42 AM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate24740 &raquo;</TD></TR><TR><TD CLASS="quote">thank that helps
How does it help that an unnamed person at an unnamed machine shop who may or may not exist can supposedly hand-hone a block down the thousandth? Even if he could, it is probably because he has hundreds of hours performing the procedure, and isnt on HT asking about it.
Old May 20, 2008 | 12:41 PM
all-mtr-teg's Avatar
Seriously, take it to shop and pay the $50-60 to get it professionally honed, or else your gonna need to buy oversized pistons and rings after you mess up the bores
Old May 20, 2008 | 04:35 PM
wed3k's Avatar
Default Re: STORE BOUGHT HONE (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
How does it help that an unnamed person at an unnamed machine shop who may or may not exist can supposedly hand-hone a block down the thousandth? Even if he could, it is probably because he has hundreds of hours performing the procedure, and isnt on HT asking about it. </TD></TR></TABLE>
yea exactly, he has access to a dial bore guage and has been machining since he was in his teens. but hes a VW, chevy and dirt bike type of guy.
Old May 20, 2008 | 04:51 PM
bluedlude's Avatar
Default Re: STORE BOUGHT HONE (wed3k)
i tried a dingle hone on a block i have. bores were somewhat out of round before i attempted and luckily i wasnt really expecting any results. worked like **** . so if your cylinders are within the out of round specs give it a shot and measure three times. if they are out of round save yourself the time and get it done right.
Old May 21, 2008 | 04:33 AM
Default Re: STORE BOUGHT HONE (bluedlude)
if you have a good strait block all is needed is to nock the glaze off the walls so the new piston rings will seat...the dingle ball type is the **** lube the walls with lots of wd40 and keep the drill moving dont stop in the middle...
Old May 21, 2008 | 04:55 AM
nate24740's Avatar
Default Re: STORE BOUGHT HONE (sleepencivic)
I DO HAVE SOME MACHINE SHOP EXPERIANCE BUT NOT WITH CARS SO MAYBE THAT WILL HELP ME GET IT DONE RIGHT. NEXT QUESTION DOES PORT AND POLISHING THE INTAKE AND HEAD GIVE YOU A LOT OF POWER ON A HONDA OR NOT
Old May 21, 2008 | 05:03 AM
d15Beta's Avatar
in theory yes.. but there are alot of variables involved, not really like in gran turismo when u add porting and polishing and the car improves right off the bat..
just porting not polishing though
Old May 21, 2008 | 06:36 AM
unusual71's Avatar
I have used a "dingle ball" type honing tool at home with good results but that was on a block that was very good, not perfect, but very good. hone came out looking perfect and never had any problems down the road, tough to get the cross hatches to come out right test it on a spare block if you can
nicko360
Northwest (Sales)
17
Jan 26, 2007 09:29 PM
type B16
Sep 29, 2006 10:11 AM
whitelightning
13
Aug 14, 2005 06:14 AM
globlctzn
Honda Motorcycles
19
Mar 13, 2005 10:49 PM
