NEED MAJOR HELP ASAP!
So I had a leak from this spot and i bought some silicone to seal it back up
I unbolted the 2 10's that were holding it off and took off the hose.
then when i put the silicone on and i was about to bolt it on..i realized that the other half of the bolt is broken half and is stuck in there. what can i do now?>
i can't drive my car and i need serious help
let me know what my options are
thanks all
thanks all
You could try dremeling a notch in there so you could unscrew it with a flathead screwdriver.
Or you could get a screw extractor kit from Sears. Check out how it works.
http://www.bimmerboard.com/forums/posts/17946
Kelvin,
I got the little tool to get that **** out bro. You're also going to need a drill small enuff to drill a small hole inside the broken bolt. I'll be outta work tomorrow around 4pm. You can come pick it up if you want and I'll show you how to use it.
mark_is_gay
May 30, 2005 03:55 PM
GUNNER666
11
Jul 19, 2004 03:40 PM
