real question h23a1 head on f22 block
Old May 18, 2008 | 08:51 PM
preludeboybmw's Avatar
Default real question h23a1 head on f22 block
ok look i cant find a real wrtie up on f22 block with us h23a1 head , i can only find the one with f23 block i want to know about the f22 block , wat my questions .
1. wat head gasket do i use?
2 . wat do i need to todo to block its self besides swaping timming parts off
3. water pump the same?
thats my questions nothing else let me know guys
Old May 19, 2008 | 08:39 AM
damm guys bump
Old May 19, 2008 | 12:50 PM
Apex1972's Avatar
Default Re: (preludeboybmw)
https://honda-tech.com/zerothread/2168311
damn guy search
Old May 19, 2008 | 06:04 PM
f22 block not a effin f23 block that guy had a f23 block , im talking about strait f22 and h23 nothing else
Old May 20, 2008 | 12:34 PM
Apex1972's Avatar
if you could read a little , you would be able to answer your own question.
does someone do your job for you at work?
Old May 21, 2008 | 02:50 PM
[freak] up [pejorative]got i do all my work i just want to ask some one who has a f22a with a h23a wat headgaskter he used and wat did he do to the head before he put it on
Old May 21, 2008 | 03:18 PM
Apex1972's Avatar
http://www.accordinglydone.com...+head
here @$$
Old May 22, 2008 | 08:22 AM
flyrod's Avatar
Default Re: real question h23a1 head on f22 block (preludeboybmw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeboybmw &raquo;</TD></TR><TR><TD CLASS="quote">1. wat head gasket do i use? </TD></TR></TABLE>
F (plug the oil drain that doesn't line up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeboybmw &raquo;</TD></TR><TR><TD CLASS="quote">2 . wat do i need to todo to block its self besides swaping timming parts off</TD></TR></TABLE>
Nothing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeboybmw &raquo;</TD></TR><TR><TD CLASS="quote">3. water pump the same? </TD></TR></TABLE>
No.
F23 is almost the same as the F22 as far as the head swap goes.
Old May 22, 2008 | 03:42 PM
so f23 head gasket or f22 head gasket?,
Old May 27, 2008 | 11:04 AM
bump i got a head gasket that says for f23 all of them and f22 its a fel pro
Old May 27, 2008 | 05:39 PM
PirateMcFred's Avatar
Learn to read. Not a lot of people here are going to serve you information on a platter especially when you're not patient or courteous .
Use the F23 head gasket If you want to know why start reading this:
https://honda-tech.com/zerothread?id=776837
The F23 and F22 blocks are virtually the same. Good luck.
Pirate
Old May 27, 2008 | 06:10 PM
95greenlude's Avatar
Default Re: (PirateMcFred)
or read this....
https://honda-tech.com/zero...ge=18
Old May 27, 2008 | 06:31 PM
ok i got the f23 gasket todau pulled head of , its a fel-pro gasket . its sort of lined up , i herd i need to take one of the little gold things that hold the layer togher , but still there are 2 holes that are blocking coolant to flow though no one said anything about this yet
heres a pic the things in the red
sivtechatchy
Jan 13, 2020 11:03 AM
Rasmusm
Jun 9, 2011 06:02 AM
sivtechatchy
Mar 6, 2009 03:45 AM
