question about my head. not sure if its a b16
Old May 18, 2008 | 06:44 PM
street_devils's Avatar
Default question about my head. not sure if its a b16
can someone plz let me know? thanks
i found this at san diegos junk yard. i picked it up for 60 bucks. just missing both cams. everything else is pretty clean
Old May 18, 2008 | 07:04 PM
wichol98's Avatar
Default Re: question about my head. not sure if its a b16 (street_devils)
its a b16
Old May 18, 2008 | 07:38 PM
Mr. EF's Avatar
Default Re: question about my head. not sure if its a b16 (wichol98)
PR3=B16 my man
Old May 19, 2008 | 04:07 AM
B20_CRX's Avatar
Default Re: question about my head. not sure if its a b16 (Mr. EF)
good find!!
Old May 19, 2008 | 09:13 AM
dem0nk1d's Avatar
unch:
Modified by dem0nk1d at 10:47 AM 5/19/2008
Old May 19, 2008 | 09:16 AM
801ef's Avatar
Default Re: (dem0nk1d)
u found it in a junkyard? and i thought i was lucky when i found a five doller bill under a seat i pulled out in a junk yard!! lucky and indeed good find
Old May 19, 2008 | 09:17 AM
dem0nk1d's Avatar
wait, i hope it came with the cam caps??? because if you don't you'll need to line bore the [freak]er if you want to reuse it.
Old May 20, 2008 | 12:21 AM
thanks to all of you guys. i was about to sell it for the same price i got it for to a shop
the guy at the shop was all happy today. so i guess i get to keep it and build my lsVtec
Old May 20, 2008 | 06:48 AM
dem0nk1d's Avatar
i'm hoping you got everything except cams. the cam caps lock the cams into the head. also each are really built with that exclusive head. The long metal peace showen in the picture is called the loss motion assembly. So you should have all the org parts for that head minus the cams and your good to go. other wise your cams will not ride correctly because of wear and friction with the new items that are not mach to that head from the factory..
Old May 20, 2008 | 10:57 AM
Default Re: question about my head. not sure if its a b16 (dem0nk1d)
yea i got all that. but i am missing one of the cam seals. or what ever its called
Old May 20, 2008 | 11:01 AM
this is waht im missing.
boomersz
Sep 11, 2007 06:01 PM
crxpwr1
Jul 16, 2007 03:56 PM
CRseXed91
Mar 31, 2007 10:13 AM
