What to look for when purchasing a 88 - 91 Honda CRX
Old May 18, 2008 | 06:11 PM
461_SS's Avatar
Default What to look for when purchasing a 88 - 91 Honda CRX
I'm new to Honda's and was wondering if you guys could give me some tips about what to look for when buying a CRX. Thanks!
Old May 18, 2008 | 06:33 PM
low91rex's Avatar
Default Re: What to look for when purchasing a 88 - 91 Honda CRX (461_SS)
Unless you have a good amount of money to spend expect to work on it. Its always little inexpensive stuff most of the time.
Old May 18, 2008 | 09:25 PM
welfarepc's Avatar
rust, bondo, blue smoke
Old May 18, 2008 | 09:49 PM
Hanmin's Avatar
Mainly rust on the quarter panels and under the car. Drive it. check fluids, check for leaks, check if all the doors line up, check the title to see if the vins match, look for a clean title, if not check for bondo. look under the carpet for frame dmg. stuff like that and just smell around to see if you can smell or see moldy ****
Old May 19, 2008 | 09:07 AM
welfarepc's Avatar
i dont mind mold... it scares ppl away but its easy to clean and dies once put in an uncomfortable environment. i got a MINT 90 Si interior for $50 that was a tad moldy. MINT!!
Old May 19, 2008 | 07:20 PM
461_SS's Avatar
Default Re: (welfarepc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote">Mainly rust on the quarter panels and under the car. Drive it. check fluids, check for leaks, check if all the doors line up, check the title to see if the vins match, look for a clean title, if not check for bondo. look under the carpet for frame dmg. stuff like that and just smell around to see if you can smell or see moldy ****</TD></TR></TABLE>
The one I looked at had rust on the quarters. The guy tried bondoing it over, but it looks ugly and needs to be done right. On the left side some of it extends into the bumper so I can easily pull the corner part out, but the rest of it looks alright. I looked at this car twice and checked the oil each time and it was full. I did not see any leaks under the car when it sat idling. The car was not lowered so I did not see any frame damage underneath. All the vins matched up (door, under the hood, and on dash). Surprisingly the body panels had what looked to be original pin striping and all the body panels lined up correctly. The car has an aem intake, new clutch, timing belt, water pump, alternator, stock si wheels and comes with some 17 motegi wheels that are a little scuffed on the right side, dc sports short throw shifter, and a cat back exhaust. The bad thing is the car has 204,000 miles on it, but the whole car drove nice and straight when i went down the road. Even when I let off the wheel it went straight surprisingly. The car didn't smell, but the windows have some track problems and also need help being aligned into there slot and the stripping on the drivers side window is a little messed up leaving a little gap in the corner where water can get through. Is that an easy fix? What you guys think? Thanks for the help so far!
Old May 21, 2008 | 05:56 PM
461_SS's Avatar
Can anyone give me more advice etc...
Old May 21, 2008 | 06:28 PM
Deetz's Avatar
Crazy Honda Guy
IMO, only 2 things....
- rust
- has the car been in an accident....you want a straight car
I wouldn't worry about mechanical work. For the age of the original engine, many upgrade with a swap and other new parts anyway. Mechanical work is easy and can be done anytime
Old May 22, 2008 | 07:10 AM
461_SS's Avatar
Default Re: What to look for when purchasing a 88 - 91 Honda CRX (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">IMO, only 2 things....
- rust
I wouldn't worry about mechanical work. For the age of the original engine, many upgrade with a swap and other new parts anyway. Mechanical work is easy and can be done anytime </TD></TR></TABLE>
Well, I wanna make the car competitive in autox sts2 division, so i need the stock motor. Or i can just try and find another d16a6 with lower miles that has good compression. The car looks like it hasn't ever been in an accident and has what looks to be original pin striping. Here are some pictures of the rust on each side covered by ugly bondo!!! That would all get redone asap though.
Pics:
There is a little sunroof rust thats bubbling, but not too bad. What you guys think? The third post up tells more about the car, but all for 2k. Think its a good deal with the rust? Thanks!
Old May 22, 2008 | 07:28 AM
0c00l's Avatar
best way to check for bondo job is bring a cheap refrigerator magnet. If you suspect bondo just see if the magnet will stick!
Old May 22, 2008 | 08:09 AM
mike-y's Avatar
I dunno.. Are you good at doing body work? Mechanical work on these cars is usually a lot cheaper than doing (good) body work and paint, so keep that in mind.
I would keep looking, but I'm from the west coast, so its rare that you see rust like that. But it seems to be fairly common on the East coast so it might be hard to find a better example. But a straight car is important, so if that rust isn't too bad it might be worth picking up.
Old May 22, 2008 | 12:47 PM
461_SS's Avatar
Default Re: What to look for when purchasing a 88 - 91 Honda CRX (mike-y)
its hard to find a crx around me that isn't rusted. lol. I prolly would not be doing the body work, but I do not know yet. All depends on what they would charge me to do it correctly. From what I looked at that was the only major areas of rust. The rockers seemed fine as well as underneath. The guy wants 2 for it. What ya think?
too_slammed
10
Jan 13, 2013 06:02 AM
michael-crxsi
Jul 31, 2010 04:43 PM
Riz1
Jun 26, 2009 02:41 PM
PA MATT
10
Apr 28, 2004 08:12 AM
Avian
Dec 19, 2001 10:36 PM
