integra gs-r swap problems
Old May 18, 2008 | 06:02 PM
pro_stargsr's Avatar
Default integra gs-r swap problems
i bought a 94 rs that was screwed and bought a 1998 JDM gsr swap. the computer that came with is a p72 obd1. i put it all in and eveything i could find showed that ecu would work( i was worried that i needed an obd2) i pinned in the vtec wire and the car fired up and purred. then i put it into gear to back it out to go to the painta shop and the engine dies under load. now it won't even idle. i pulled the codes , 20 and 22 came up but the jdm engine has no oil pressure switch. and 20 is ELectronic load detector so i went over the car looking for shorts and everything seemed fine. am i missing something or completly wrong with something?
Old May 18, 2008 | 09:32 PM
dc2_97teg's Avatar
Default Re: integra gs-r swap problems (pro_stargsr)
Well your best bet is to check the ecu. If you have a friend who has the same ecu you could try that. If not my next step would to purchase a jdm ecu. But don't expect to pass emissions.
Old May 19, 2008 | 12:35 PM
Default Re: integra gs-r swap problems (dc2_97teg)
would it throw an ecu code if thats the problem?
Old May 19, 2008 | 07:02 PM
dc2_97teg's Avatar
That could be one of the reason is you burnt your ecu if im saying that correctly. Cause i had an ecu that threw an o2 code and it was working fine when i got it. But i had a bad ground i believe. So you could check the grounds, like you stated shorts, and/or borrow a friends ecu. Best bet of all is to get your hands on a helms manual
frankenghia
Dec 10, 2011 08:43 AM
Eli Mac 67
Jul 12, 2007 06:07 PM
Eli Mac 67
Jun 11, 2007 04:45 PM
Hatchorama
Dec 27, 2006 07:06 PM
ctr status
Sep 14, 2006 05:10 PM
