JDM B18C...spun #3 rod bearing...need opinions on my options...
Old May 18, 2008 | 04:06 PM
blackexvtec's Avatar
Default JDM B18C...spun #3 rod bearing...need opinions on my options...
So after three days of research on my end, I would like some opinions from others out there.
Here is what happened...the rod bearing on #3 spun...started knocking...thus rendering my crank and that rod useless...totally out of round. My setup is a JDM B18C with 9.5:1 pistons coupled with a jackson racing supercharger...
I'm getting rid of the blower and going to a turbo setup...with that in mind...
Should I replace the crank/rods with the B16A crank and rods, while yes...losing .2 liters of displacement...I'm bringing my r/s ratio up to around 1.73...
Or...go with the LS crankshaft and LS rods and remove the oil squirters to keep my stroke around the same that I have now...
Or just stick with the OEM B18C crankshaft and rods?
Input greatly appreciated...
Old May 18, 2008 | 05:40 PM
Hybrid96EK's Avatar
Default Re: JDM B18C...spun #3 rod bearing...need opinions on my options... (blackexvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackexvtec &raquo;</TD></TR><TR><TD CLASS="quote">So after three days of research on my end, I would like some opinions from others out there.
Input greatly appreciated...</TD></TR></TABLE>
B16 crank/rod idea is retarded. Not only will you loose displacement, you will severly drop compression as well. Remember, B18C has a taller deck height. Not a good idea...
You can use the LS rods/crank with the oil squirters, just requires some slight bending.
Personally I would source another crank.
bzyq2001
Oct 21, 2010 10:13 AM
youre_scum
Aug 10, 2007 04:02 PM
pornstar4777
Apr 19, 2006 03:15 PM
Zackyt
Aug 19, 2004 09:27 AM
love2xlr8integra
May 2, 2004 08:00 PM
