Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 ex coupe looking for a mild lowering
Old May 18, 2008 | 03:45 PM
nation's Avatar
Default 01 ex coupe looking for a mild lowering
7th gens are new to me.using the stock struts/shocks what spring will lower me 1.5",increase handiling andstill ride nice.i was looking at S2 or prokits
Old May 18, 2008 | 03:48 PM
katzenjammer84's Avatar
Skunk2 makes horrendous suspension parts IMO, ProKits work but the drop is minimal. I also HIGHLY recommend new shocks to accompany your springs, namely Koni Yellows or KYB AGX's.
And check the FAQ at the top of the forum, it'll probably answer every question you have.
Old May 18, 2008 | 04:13 PM
01em2's Avatar
Default Re: (katzenjammer84)
the eibach pro kits give the 7th gen civic a 1 inch drop all around. will it be ok with stock shocks?
Old May 18, 2008 | 04:34 PM
Describe "ok"
The problem is the stock struts simply do not have the valving to deal with a lowered ride height and increased spring rates.
So even if you don't ruin the OEM struts right off the bat, the ride will still be pretty rough and bouncy, not to mention handling will be far from ideal.
Old May 18, 2008 | 06:13 PM
Harlowe's Avatar
Function>Fashion
I'm pretty low on stock struts , Does not ride good though...
angrysmileyface
Jan 10, 2011 09:26 PM
RedRocketDX
Suspension & Brakes
Jul 11, 2007 06:20 PM
skeelo
Suspension & Brakes
Nov 7, 2005 09:55 AM
stoopid215
Sep 19, 2002 08:30 AM
honda_2468
Feb 24, 2002 12:01 PM
