is there aftermarket for this?
Old May 18, 2008 | 03:19 PM
IAluder95's Avatar
Default is there aftermarket for this?
Part numbers 7,6,5,4,28,27? of course im redoing my suspension and all the bushings are GONE the bolt #28 is just spinning on part #7 and not coming off and wont re tighten so im going to cut it off. (only way) i want to know if some company makes a kit for this cheaper than the dealer prices or same as. i checked ES and didnt see it listed.
i hate my car, fing 16 years old parts never want to work with you.
Old May 18, 2008 | 03:25 PM
Hawkze_2.3's Avatar
Default Re: is there aftermarket for this? (IAluder95)
Bad pic, but Prothane makes them. I got mine from prostreetonline.com, but they are currently on a shelf in the garage
Old May 18, 2008 | 03:28 PM
slamdlude's Avatar
I know that you can get the bushings from autozone in the ricer section. Part number 7. I don't know maybe they will have that also.
Old May 18, 2008 | 03:52 PM
IAluder95's Avatar
is there a kit that includes part #7? im going to cut it and was curious if i have to order from honda a new one.
Old May 18, 2008 | 05:27 PM
Hawkze_2.3's Avatar
Default Re: (IAluder95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 &raquo;</TD></TR><TR><TD CLASS="quote">is there a kit that includes part #7? im going to cut it and was curious if i have to order from honda a new one.</TD></TR></TABLE>
I think you would just have to order that from Honda, or you could make one with some hardware and a Heim joint
Old May 18, 2008 | 07:12 PM
CADster's Avatar
secluded luder over at preludepower.com make adjustable end links for the 3rd gen lude. maybe he can revise his design for 4th gens.
Old May 19, 2008 | 06:20 AM
IAluder95's Avatar
im not a member of that board. it would be nice if he did.
how ever do they make aftermarket tie rods? i was thinking of buying new ones that are lighter and have better bushings. just trying to update all my suspension.
Old May 19, 2008 | 06:31 AM
Altilude's Avatar
just curious...(and maybe a bit obvious) but you are holding the flats on part 7 with a wrench, when you are trying to undo the nut correct?
Old May 19, 2008 | 08:01 AM
IAluder95's Avatar
yes.
Old May 19, 2008 | 07:47 PM
snobordboy's Avatar
Moderator
I know they had the whole piece with all bushings and washers as a kit for accords at checker, I would assume they have it for preludes as well.
Old May 19, 2008 | 07:52 PM
IAluder95's Avatar
would the accord parts work?
Old May 20, 2008 | 05:40 AM
IAluder95's Avatar
think this will work? its cheaper than the prostreet kit.
Old May 20, 2008 | 11:56 AM
jlude90's Avatar
what is "this" there are some knowledgeable people here, but asking them to just visually identify a part like this is asking a bit much
Old May 20, 2008 | 01:59 PM
IAluder95's Avatar
its a set of ES bushing that are labeled Universal Mounts/Isolators
Old May 20, 2008 | 08:02 PM
IAluder95's Avatar
bump
Old May 20, 2008 | 08:55 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 &raquo;</TD></TR><TR><TD CLASS="quote">bump
It'll work if you can make it work
Old May 21, 2008 | 06:20 AM
BlackCatt's Avatar
x2. I like making things work, but sometimes I f%&K it completely . Goodluck with the refit man.
Old May 21, 2008 | 07:05 AM
E-Money's Avatar
Default Re: is there aftermarket for this? (BlackCatt)
i had a problem getting old endlinks off my sway bar in the rear. they just gotta be zipped off. just buy new pieces from honda. i would recommend dropping the whole swaybar off when trying to do this.
Old May 21, 2008 | 09:47 AM
97_type-sh's Avatar
while your down there get a new rear sway bar, they do magic to your handling
Old May 21, 2008 | 11:34 AM
yOnKiNaToR's Avatar
Default Re: (97_type-sh)
if you google it you can find a couple places that sell the endlinks .i know statracing.com has them for like 43 bucks. slhondparts.com has them for like 55 or something.
i did that and then used the bushings that came with es bushing set.
Old May 21, 2008 | 01:30 PM
IAluder95's Avatar
im only working on the front. im on a budget so i cant really drop hardcore money into the suspension for another 3 months. damn college.
either way, thanks for the advice. i got new sway bars already; bought them last year. i pretty much have every suspension part, i just didnt do bushings.
fuzzysig
Suspension & Brakes
17
Jul 26, 2017 06:55 PM
mazdabish
Suspension & Brakes
Apr 17, 2014 07:48 PM
CWTegRNo.160
Apr 23, 2007 07:35 PM
Boosthead
Oct 9, 2004 07:52 PM
JTCdudeman
Apr 13, 2003 09:33 PM
