Noise from tire/wheel bearing/hub/axle? Help?
Old May 18, 2008 | 02:33 PM
EX-T's Avatar
Default Noise from tire/wheel bearing/hub/axle? Help?
I have a '99 EX coupe and about 2 years ago when I was replacing my clutch, I couldn't get the axle out of the hub, I tried heating it, pb blaster, everything. Ever since there's been a noise coming from that side that sounds kind of like choppy tires but it's not b/c I've put 2 different sets of wheels on it and the noise is still there! Just today I got the axle out and put a new one in it but it still makes the noise. It's definitely coming from the side with the axle problems. It's sounds like "wahh wahh wahh" and it speeds up and slows down with the speed of the vehicle...
What could it be? Is the wheel bearing bad? If it is the wheel bearing, is it cheaper to just get a new hub assembly? Any help is greatly appreciated.
Old May 18, 2008 | 02:38 PM
obuhmyuh's Avatar
Default Re: Noise from tire/wheel bearing/hub/axle? Help? (EX-T)
is the axle completely seated into the tranny/hub?
Old May 18, 2008 | 05:01 PM
EX-T's Avatar
Default Re: Noise from tire/wheel bearing/hub/axle? Help? (obuhmyuh)
yeah, if it's not all the way in the tranny, the clutch won't engage. And I made extra certain the axle nut is all the way tightened...
Old May 19, 2008 | 05:47 AM
EX-T's Avatar
Somebody, anybody?
Old May 19, 2008 | 11:47 AM
shortlid's Avatar
I have the same noise thought it was the bearings it was not it was the front disc shilds rubbing against the rotor during turns and at diff. temps!
Old May 19, 2008 | 12:52 PM
EX-T's Avatar
Default Re: Noise from tire/wheel bearing/hub/axle? Help? (shortlid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortlid &raquo;</TD></TR><TR><TD CLASS="quote">I have the same noise thought it was the bearings it was not it was the front disc shilds rubbing against the rotor during turns and at diff. temps! </TD></TR></TABLE>
holy ish! I didn't even think of that! I'm checking that as soon as I get home!!!!! to you if that's what it is!
Old May 19, 2008 | 12:56 PM
egstockboosted's Avatar
just to be safe the cv boot too..
Old May 19, 2008 | 01:15 PM
EX-T's Avatar
Default Re: Noise from tire/wheel bearing/hub/axle? Help? (egstockboosted)
boots are fine, i just put a new axle on it...
Old May 19, 2008 | 01:16 PM
alright ya id say check out the shields than. and if its not that.. start a new thread on tranny issues lol
tobytigger
Jan 11, 2014 01:41 PM
Steve LeB
Oct 28, 2011 11:58 PM
BOOSTED_JDM_DB8
Dec 26, 2007 12:15 PM
dc2doi
Oct 15, 2007 11:23 AM
fstgsr
Oct 29, 2003 09:03 AM
