motor don gone retarded.!!!!! help from you all motor gurus
Old May 18, 2008 | 01:46 PM
93hondaboy's Avatar
Default HELP motor don gone retarded.!!!!! help from you all motor gurus
i have done a few allmotor builds on my own and they make decent power 190 plus or so with decent tuning.
i recently put together a motor gsr with work etc
skunk2 pro mani
skunk2 pro throttle body
gsr head ported and polished
rc 310 injectors
aftermarket cams unknown??????????
the block is a ctr but had typer crank and everything put in to it has a lil more get up.
but problem is that when i had it running decent with the ctr cams it ran great pulled like it was pissed off or something. now i put much bigger ones it runs like **** and it like ya step on it it takes forever to get going. its like the damn thing is waiting on an invite to hurry up and go. someone please gimme an ideas or suggestiions ya i know i need a tune but damn this **** is not to pleasing
also if i raise the fuel pressure on the 310 injectors will thats cause the car to run a bit rich or should i turn down the fuel preesure a tad
Modified by 93hondaboy at 11:09 PM 5/18/2008
Modified by 93hondaboy at 11:21 PM 5/18/2008
Old May 18, 2008 | 02:22 PM
all-mtr-teg's Avatar
Default Re: HELP motor don gone retarded.!!!!! help from you all motor gurus (93hondaboy)
Did you tune after the new cam install? Degree the cams? Valve adjustment?
Old May 18, 2008 | 02:27 PM
93hondaboy's Avatar
Default Re: HELP motor don gone retarded.!!!!! help from you all motor gurus (all-mtr-teg)
JUST DID A VALVE ADJUSTMENT 7 IN 8 EX AND I DIDNT GET IT RETUNED YET BUT DAMN THE CAR RUNNING LIKE AN ***. STILL
THE FUEL PRESSURE I UPPED IT A BIT JUST TO BE ON THE SAFE SID E BUT STILL RUNNING LIKE TRASH
Old May 18, 2008 | 02:42 PM
UncleD's Avatar
Title of this thread just cracks me up hahhahahaha. Get the car tuned asap.
Old May 18, 2008 | 03:40 PM
BMo Tuning's Avatar
STAR
You can't expect the car to run well or be fast without getting a retune when you do something as big as changing cams............
Get it retuned and report back.
Old May 18, 2008 | 03:56 PM
93hondaboy's Avatar
Default Re: (BMo Tuning)
well sorry to sound so demanding but check this out . i had an lsvtec with type-r heead and skunk2 everything and some low compression pistions sames cams and the motor hauled *** untuned and made 190 horse on the head at my old shop. and i was happy then tuned the car for spray and was even happier i just dont get why this motor gotta be the damn difficuilt egg
Old May 18, 2008 | 04:17 PM
00MRSi's Avatar
Default Re: (93hondaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hondaboy &raquo;</TD></TR><TR><TD CLASS="quote">well sorry to sound so demanding but check this out . i had an lsvtec with type-r heead and skunk2 everything and some low compression pistions sames cams and the motor hauled *** untuned and made 190 horse on the head at my old shop. and i was happy then tuned the car for spray and was even happier i just dont get why this motor gotta be the damn difficuilt egg</TD></TR></TABLE>
Umm Ok.
Old May 18, 2008 | 05:11 PM
soulpwr's Avatar
Default Re: (00MRSi)
Are you sure the timing isnt off?
Old May 18, 2008 | 05:26 PM
mar778c's Avatar
Community Builder
Community Influencer
Tune it, if you want it to run well.
Old May 18, 2008 | 05:27 PM
93hondaboy's Avatar
Default Re: (soulpwr)
well im pretty sure the timing is fine. just not sure if fuel is the problem oro what it is. there is something not right though
Old May 18, 2008 | 05:42 PM
BMo Tuning's Avatar
STAR
Just get the damn car tuned, thats your problem.
You can't just throw parts in an engine without tuning and expect it to be fast or even run at all.
My car felt like **** when I put a ported head on it b4 it got retuned, after the retune it was one of the strongest feeling NA b series I had ever felt (lol I haven't ridden in many fast ones).
Get that jonx tuned and make sure timing is correct. Oh and find out wtf cams they are.
Old May 18, 2008 | 06:03 PM
93hondaboy's Avatar
see thats the problem i have been in to many fast *** b series and very unhappy with mine right now. but im a get it tuned and see if theresx any difference
Old May 19, 2008 | 12:13 PM
93hondaboy's Avatar
maybe lack of timing would probably be the problem. im off to the shop to see whats good
Old May 19, 2008 | 12:20 PM
BMo Tuning's Avatar
STAR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hondaboy &raquo;</TD></TR><TR><TD CLASS="quote">maybe lack of TUNING would probably be the problem. </TD></TR></TABLE>
Fixed.
Old May 19, 2008 | 12:28 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hondaboy &raquo;</TD></TR><TR><TD CLASS="quote">maybe lack of timing would probably be the problem. im off to the shop to see whats good</TD></TR></TABLE> Maybe less fuel pressure for the bigger injectors.
Old May 19, 2008 | 12:30 PM
91 HONDAsaurus rex's Avatar
sounds like the timing is too much on the retarded side. Is it slow at first then kind of gets going? If you went bigger cams did you degree them right or at all? Take it to a tuner engine building isn't just slapping parts together.
Old May 19, 2008 | 12:32 PM
BMo Tuning's Avatar
STAR
Default Re: (91 HONDAsaurus rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91 HONDAsaurus rex &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the timing is too much on the retarded side. Is it slow at first then kind of gets going? If you went bigger cams did you degree them right or at all? Take it to a tuner engine building isn't just slapping parts together.</TD></TR></TABLE>
[freak] dat y0 i be slap'n my engines together and makin dat mad HP.
Old May 19, 2008 | 12:35 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hondaboy &raquo;</TD></TR><TR><TD CLASS="quote">maybe lack of READING would probably be the problem. im off to the shop to see whats good</TD></TR></TABLE>
Fixed. X-D
Old May 19, 2008 | 02:14 PM
mar778c's Avatar
Community Builder
Default Re: (ComeOnKip)
Threads like this are priceless.
Old May 20, 2008 | 04:28 AM
93hondaboy's Avatar
Default Re: (mar778c)
car runs a tad bit better after messing with the timing a lil but im just gonna wait till this weekend and get my **** tuned and call it a day ill surely put up numbers though
Old May 20, 2008 | 05:13 AM
alterdcreations's Avatar
you still dont know what cams your running?
Old May 20, 2008 | 05:30 AM
projectcivicjp's Avatar
Default Re: (alterdcreations)
you really need to find out what cams you are running man! thats not good to just put something inside your motor and not know what they are. Pull them off and look for any markings and take them to get measured.
you've heard this a thousand times in this thread but dont expect your motor to run top notch without tuning. ESPECIALLY after making a HUGE adjustment like changing your cams and not even knowing what they are. You would be exceptionally pissed off if those "i dont know" cams turned into "BOO-BOO" cams and one take a big fat duece inside your head
Old May 20, 2008 | 07:02 AM
Default Re: (projectcivicjp)
They're probably stock B16a cams, that's why he got the power lag in vtec and FPR is at 47 psi with untuned RC310 injectors
Old May 20, 2008 | 04:59 PM
93hondaboy's Avatar
Default Re: (all-mtr-teg)
sorry to say but there not stock b16a haha
Old May 20, 2008 | 08:12 PM
Did you finally take a pic of the dizzy ends of the cams? Post them up if you did, or did you measure the lobes?
