car wont start 90 civic ls swap
well i replaced the therostat yesturday and i connected everything back and tryed turning on the car fuel pump is not priming nor the ecu turns on when i turn the key. its a 90 civic with an ls swap it was running fine before i replaced the thermostat. i have checked main relay and all the fuses . im stumped not . any help would be great thanks
Well its possible. Just make sure its tights on the housing.
Check the ECU fuse in your fuse box in the engine bay. I think its #10. But dont hold me to that. Just look on the fuse box cover and see where it is. It sounds like that fuse blew.
crookson speed
Feb 25, 2014 12:02 PM
White1979
Apr 8, 2004 12:40 PM
