CRX brake booster bolts?
Old May 18, 2008 | 08:31 AM
Spikey640's Avatar
Default CRX brake booster bolts?
well, after doing a complete front disc replacement found out that i have a faulty brake booster
i know there are bolts that need to be removed from the cabin in order to take the brake booster out, but i dont know which ones
help anyone?
Old May 18, 2008 | 09:09 AM
Hondacivic90ed's Avatar
Default Re: CRX brake booster bolts? (Spikey640)
you're going to have to remove the master cylinder and then remove the cover from the brake booster. There are two c-clips on the studs that held the master cylinder. Take the c-clips off and then the metal cover to the brake booster will come off. This is the only way you will have enough room to remove the brake booster. Otherwise you would have to remove the intake manifold. There are 4 nuts inside near the pedal assembly bracket. 3 of the nuts are hard to get to 1 is nearly impossible without cutting your hand to pieces and using multiple universal sockets and joints. You're also going to have to remove the yoke from the brake pedal. There is a cotter pin holding a pin that goes through the yoke and through the brake pedal. Once you've got that all disassembled the booster should come out. You may have to remove the yoke from the shaft to get enough clearance to get the booster all the way out.
trailblazer
Aug 23, 2016 07:16 AM
The DX Rex
13
Nov 4, 2013 05:06 AM
MNCRXSi
Nov 1, 2006 06:49 PM
B18C Turbo
Aug 30, 2006 12:46 PM
special_edition
Mar 29, 2004 08:07 PM
