What transmissions will work with a D16Y7?
Old May 18, 2008 | 07:15 AM
DarkSideofOZ's Avatar
Default What transmissions will work with a D16Y8?
I meant D16Y8, not Y7, my bad, it's the V-TEC one.
I'm thinking about getting this 99 Civic EX V-tec, the engine is fine but the transmission is grinding on gears 1-3, so i figure it'd be cheaper to just buy another one off the local market around here rather than have it rebuilt. But I need to know, what all transmissions are compatible.
Edit: 5spd manual, not auto.
Thanks for the help.
Modified by DarkSideofOZ at 4:20 PM 5/18/2008
Modified by DarkSideofOZ at 4:27 PM 5/18/2008
Modified by DarkSideofOZ at 4:35 PM 5/18/2008
Old May 18, 2008 | 07:53 AM
jry2598's Avatar
Default Re: What transmissions will work with a D16Y8? (DarkSideofOZ)
all manual d series tranny will bolt on to your engine 92-00 civic.....just decide on what gearing you want or if on a budget get on from a cx or dx and just run with it....
Old May 18, 2008 | 10:35 AM
93egSLEEPER's Avatar
Default Re: What transmissions will work with a D16Y8? (jry2598)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jry2598 &raquo;</TD></TR><TR><TD CLASS="quote">all manual d series tranny will bolt on to your engine 92-00 civic.....just decide on what gearing you want or if on a budget get on from a cx or dx and just run with it.... </TD></TR></TABLE>
i recommend the ex/si tranny from the 92-95 civic.... shortest gear ratios and pretty solid.
turbo-d
Oct 13, 2023 02:54 PM
JLUDE01
15
Nov 15, 2014 01:23 AM
Cltntroxell
Jun 24, 2013 05:11 PM
dargham
Transmission & Drivetrain
Feb 3, 2013 08:09 AM
.:Made in OC:.
Sep 21, 2007 07:56 PM
