Aftermarket Sway Bars vs. ITR rear sway
Old Jul 15, 2002 | 06:12 AM
GSR-REX's Avatar
New User
Default Aftermarket Sway Bars vs. ITR rear sway
Hello all..hope everyone's weekend was good!
I am in the market for a rear sway bar for my GSR. I was wondering if any 22mm aftermarket rear sway is comparable to the ITR Rear Sway bar. The reason I am asking is because I may buy a used Progress 22mm bar from a fellow H-T member and I want to know if I should spend my $$ on that or should I get an ITR one?
Any input (except haters ) is appreciated!
-Thanks
Old Jul 15, 2002 | 07:29 AM
GSR-REX's Avatar
New User
Default Re: Aftermarket Sway Bars vs. ITR rear sway (GSR-REX)
Nobody has an opinion on aftermarket sway bars??? C'mon guys, help me out here!
Old Jul 15, 2002 | 08:00 AM
Scary1109's Avatar
the only experience i have is with my itr bar, i love it. but i am pretty sure most 22mm bars will be similar in handling. just my .02
-Scary
Old Jul 15, 2002 | 08:04 AM
GSR-REX's Avatar
New User
Default Re: Aftermarket Sway Bars vs. ITR rear sway (Scary1109)
Thanks Scary...I'm also wondering about the quality of Progress. Does anybody have experience with this particular brand? Thanks
Old Jul 15, 2002 | 09:16 AM
brainwo's Avatar
New User
Aftermarket Sway bar are a little easier to install.. fit a little better if you using GSR/LS lower control arm.
Old Jul 15, 2002 | 09:17 AM
Scary1109's Avatar
Default Re: Aftermarket Sway Bars vs. ITR rear sway (brainwo)
what bar are you using, and how do you like it?
Thanks
Scary
Old Jul 15, 2002 | 09:23 AM
stegs's Avatar
Have you looked at Comptech. Its a tie bar, and sway kit. Pretty slick.
Old Jul 15, 2002 | 10:09 AM
Calavera's Avatar
Default Re: Aftermarket Sway Bars vs. ITR rear sway (stegs)
The combo also costs 360+shipping.
Old Jul 15, 2002 | 11:17 AM
Malice's Avatar
New User
i have the skunk2 21 mm swwaybar. I like it. the progress and ITR bar are 22mm, so they should perform the same
Old Jul 15, 2002 | 11:19 AM
GSR-REX's Avatar
New User
Default Re: Aftermarket Sway Bars vs. ITR rear sway (Calavera)
I hear ya!! I love Comptech and all, but that is a bit pricey for that setup!!
Old Jul 15, 2002 | 11:20 AM
GSR-REX's Avatar
New User
Default Re: Aftermarket Sway Bars vs. ITR rear sway (MaliceGSR)
Thanks Malice....I'm sure they'll perform the same, I'm just wondering about Progress' quality. I know the OEM ITR will be high quality, but I've never heard anythin (bad or good) about progress equip.
Anybody have experience with Progress? TIA
Old Jul 15, 2002 | 11:42 AM
Malice's Avatar
New User
i know a couple of peeps ruinning progress bars on integras and civics. they have had no problems
Old Jul 15, 2002 | 12:38 PM
GSR-REX's Avatar
New User
Any clue how long they've had them on? I wonder if they last as ong as OEM?
Old Jul 15, 2002 | 12:42 PM
98DC2's Avatar
do not get skunk2 rear lower tie bar unless you plan on moving your ABS lines & rewelding them under control arm i bought one for my 98 GS-R, came across this problem. i'll probably go w/ comptech setup.
Old Jul 15, 2002 | 12:45 PM
GSR-REX's Avatar
New User
Default Re: Aftermarket Sway Bars vs. ITR rear sway (98lagen)
Cool...Thanks for the info
Old Jul 15, 2002 | 04:06 PM
bruthaboost's Avatar
The last time I looked at the progress rear sway bar install, it suggested getting some welding. Other than that potential inconvience, it's design looked solid. I have the beaks/itr combo and love it. Rotation is wonderful.
Old Jul 15, 2002 | 04:39 PM
zilverz's Avatar
I like Suspension Techniques anti-roll/swaybar kit
its cheap like 250 .. comes with everything you need... and the bars are soooo heavy duty and quality its insane ... i stay planted on the ground taking turns at 70/80mph
kids dont try that at home (:
if there is any negative on them .. they are sooo heavy duty its gonna add a little weight ... you can seriously work out with the rear sway bar (;
Old Jul 15, 2002 | 05:42 PM
Scary1109's Avatar
Default Re: Aftermarket Sway Bars vs. ITR rear sway (bruthaboost)
i will be installing that exact kit this weekend, any advise?
Thanks
Scary
Old Jul 15, 2002 | 06:43 PM
AlphaKennyWun's Avatar
Default Re: Aftermarket Sway Bars vs. ITR rear sway (zilverz)
so you have the front and rear installed?
Ive been wanting to get the eibach kit f and r but want to hear someoen elses opinion first.. S/T and Eibach are probably very similar but im going with the eibach theme throughout...ghey i know but I like.
Old Jul 15, 2002 | 06:56 PM
MattG's Avatar
New User
I have the Comptech tiebar/swaybar kit. Very nice, adjustable, and easy to install. For the budget I would recomend a factory ITR bar with the kits sold on the board.
Old Jul 15, 2002 | 09:03 PM
Cramerox's Avatar
Default Re: Aftermarket Sway Bars vs. ITR rear sway (MattG)
Im surprised BSQ isnt in here yet...he prolly had some experience with different bars.
Old Jul 15, 2002 | 11:42 PM
PaChiLa Leader's Avatar
You should do some search, dude
Brand NEW ITR rear sway bar(22mm) with BSQ mounting kit only cost 110 shipped
Old Jul 16, 2002 | 05:39 AM
BSQ's Avatar
BSQ
Default Re: Aftermarket Sway Bars vs. ITR rear sway (Cramerox)
You guys are doing a fine job without me . I haven't heard any feedback on the Progress rear swaybar on a G3 Integra, only on the G2 Integra.
The Type-R rear swaybar is the most popular swaybar by far. Mainly because of the cost ~$105-$110, its an OEM part and it is extremely reliable and trouble-free.
The Comptech rear tie bar/swaybar combo is another popular choice, but it is rather pricey ($360-$400). It is has an integrated tie bar and it is adjustable (3 position). But the endlinks can become rather noisey.
Eibach and Suspension Technique both sell a front and rear swaybar kit for ~$250. But, I haven't heard much feedback on either of these.
A good swaybar combination for the G3 Integra is a 24mm front swaybar and a 22mm rear swaybar (same combination as the Integra Type-R). This setup will give a very neutral handling balance (ie. no understeer/no oversteer).
Old Jul 16, 2002 | 05:54 AM
Scary1109's Avatar
Default Re: Aftermarket Sway Bars vs. ITR rear sway (BSQ)
neutral handling is very key
-Scary <--- who still loves a little oversteer, but hey who doesn't
Old Jul 16, 2002 | 06:02 AM
BSQ's Avatar
BSQ
What is the size of the ST swaybars (front and rear)?
