need help no spark
Old May 17, 2008 | 09:02 PM
b_boysaiyan's Avatar
Default need help no spark
ok i have a 97 civic with a d16y8 5 speed.. Car was driving perfect , i took a turn and car then shut off .when i looked i found out it had no spark . i had replace and tested the coil and ignitor on another car .my ignitor and coil pack and ecu works on the other car and i have no wires cut and no blown fuses but i still have no spark .i tested my coil ,ecu (rinning a p28 in my civic with jumper harness) and ign in a 95 honda civic and it started right up i didnt get a try another obd2 dizzy because no one around me right now has one . i was wondering is there a relay or something else that could be wrong .looking to fix this asap but have no clue.
Modified by b_boysaiyan at 9:23 AM 5/18/2008
Old May 17, 2008 | 09:40 PM
mormonboy's Avatar
Default Re: need help no spark (b_boysaiyan)
omgyourgrammersuckssofingbad!!!
Old May 18, 2008 | 08:24 AM
ttt and mormonboy i glad you help me so much answering nothing
Old May 18, 2008 | 08:52 AM
illinoishondaboy's Avatar
Default Re: (b_boysaiyan)
cap and rotor look ok? no carbon scoring on any of it? check that out make sure everything is making contact. otherwise you might have some wiring issues somewhere
Old May 18, 2008 | 09:35 AM
yea cap and rotor look good i mean i never had any problems with the car i drove it every day and had no problems but yesterday it just shut off.
Old May 18, 2008 | 09:43 AM
90_EX_Civic's Avatar
timing belt??????
Old May 18, 2008 | 09:46 AM
yea i checked my timing and its good.that was the first thing i checked and then i checked for spark and had no spark
Old May 18, 2008 | 09:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_boysaiyan &raquo;</TD></TR><TR><TD CLASS="quote">yea i checked my timing and its good.that was the first thing i checked and then i checked for spark and had no spark</TD></TR></TABLE>
so it cranks then? just thinking of simple things to check here....... grounds????
Old May 18, 2008 | 10:01 AM
yea it cranks up perfectly every thing works i have check every thing except the relay for the dizzy i cant find it .
Old May 18, 2008 | 10:29 AM
now when you said you checked your timing, you took the valve cover off right? and have what about your spark plug wires?
RedEJTwo
May 9, 2015 01:11 PM
toeknee360*
Oct 5, 2009 11:57 PM
91zchatch
Classic Hondas
Aug 8, 2009 01:02 PM
egluism33
May 25, 2008 06:17 PM
VvPeachyvV
Jun 15, 2006 09:59 PM
