91 si tranny in 88 si
Old May 17, 2008 | 08:20 PM
anth9998's Avatar
Default 91 si tranny in 88 si
i have an 88 crx si with a blown tranny, i was wondering if a 91 si tranny would work. i heard there is some difference in the 88's. thanks
Old May 17, 2008 | 08:49 PM
draperj09's Avatar
Default Re: 91 si tranny in 88 si (anth9998)
There are some ways you can identify each transmission. I'm sure you could search and find them and check it out. If they both match up
Old May 18, 2008 | 06:07 AM
jlicrx's Avatar
if the 88 has the original transmission, you would need to swap out the 88 clutch disc and use the 89 Si clutch disc in order to use the 91 transmission
Old May 18, 2008 | 07:49 AM
thevtecnician's Avatar
Default Re: 91 si tranny in 88 si (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">if the 88 has the original transmission, you would need to swap out the 88 clutch disc and use the 89 Si clutch disc in order to use the 91 transmission</TD></TR></TABLE>
The 88 clutch discs have more splines than the 89-91 discs.check out this link on how to I.D. What you really have
https://honda-tech.com/zerothread?id=1551508
ALSO lol, if you need an 89-91 clutch disc I have a low mileage disc I could sell you for really cheap!
Old May 18, 2008 | 10:27 AM
anth9998's Avatar
Default Re: 91 si tranny in 88 si (thevtecnician)
thanks for all the help.. i understand now, i saw a transmission for a 91 si on craigslist and was thinking about buying it, good thing i asked first. thanks again.
Old May 18, 2008 | 11:14 AM
mario_pic's Avatar
i got a 88 dx u chould make a si tranny its in amazing shape i also got a 91 si the diffrence is the splines the 91 has more and the 88 has less so if u want it to fit ud need to use a new fly wheel if u want a crazy mod i found out get a 96 hydro clutch and flywheel and press plate the car will grab like its a stage 2 race clutch stock lol it works well still runing it just dont use the cheep ebay clutch cables lol
Lennart89
10
Dec 10, 2010 04:48 AM
skimb37
May 30, 2007 04:59 PM
wfocrx
Sep 24, 2006 10:46 PM
ef9one6
Aug 6, 2003 01:17 PM
CRXracer88
Feb 13, 2003 06:28 PM
