h22 help
Old May 17, 2008 | 06:14 PM
superfast666's Avatar
Default h22 help
ok i have a h22 thats got darton sleeves in cylinder four the sleeve began to sink in all cylinders the rings blew what is the largest the cylinders can be bored and can a cylinder that has begun to sink fixable i will post pics soon
Old May 17, 2008 | 07:34 PM
GhostAccord's Avatar
Default Re: h22 help (superfast666)
Are they wet or dry sleeves?
I'm going to assume your block has the Darton dry sleeves. I would think it would be hard for wet sleeves to sink down if the block was machined properly. As far as I know the dry sleeves cannot be bored they have to be replaced. If they are slipping then the remaining FRM H sleeves are probably to large and out of spec for the dry sleeves. I would say that you are probably looking at having to get the block machined for a set of wet sleeves.
Schister66
May 20, 2016 05:45 AM
darkstarsi
Nov 18, 2011 06:13 PM
Bigplans06
Feb 16, 2011 08:10 AM
pentaq
Jul 27, 2005 02:01 PM
Dragline
Apr 26, 2005 04:01 PM
