disc conversion
Old May 17, 2008 | 03:25 PM
area608EG's Avatar
Default disc conversion
what cars rear disc setup can be swapped on to a eg dx model. and what do i all need off the donor car and what can be saved. thanx
Old May 17, 2008 | 04:26 PM
danomatic93's Avatar
Whoa, you're from Milwaukee, sweet. Please search...
...but I'll be nice any 92-95 with Disc (only some ABS models had them) any 94-01 tegi with disc.
You need the rear trailing arm with the e-brake cables still attached.
You will probably need to replace the rear trailing arm bushing, rebuild the calipers, replace the pads and maybe rotors too. Also check that the wheel bearing is still okay.
Old May 17, 2008 | 05:23 PM
dudeomega2000's Avatar
Default Re: disc conversion (area608EG)
Ditto bro... Search!
But i will be nice as well. the 94-01 integra rear trailing arm with discs will suit your purpose or the 99-00 Si rear disc brakes are the same.
Old May 17, 2008 | 05:39 PM
Dc2Fiend's Avatar
just get a full disc conversion off an Integra and swap it in your eg.
95dxb18b1
Aug 29, 2011 06:47 PM
raytownracer
Jan 29, 2009 03:26 PM
Chef Andre
Suspension & Brakes
Nov 13, 2008 03:59 PM
jonathanraycamacho
Jul 2, 2007 01:56 PM
Steak84SS
Jun 25, 2004 08:07 AM
