ARP rod bolts wont let cap come off!!
Old May 17, 2008 | 01:42 PM
TealEG!'s Avatar
Default ARP rod bolts wont let cap come off!!
Modified by TealEG! at 5:40 PM 6/3/2008
Old May 17, 2008 | 01:59 PM
crip's Avatar
Default Re: ARP rod bolts wont let cap come off!! (TealEG!)
sound like the machine shop f'd up something. i would take them back there and ask them how they expect you to get them off.
Old May 17, 2008 | 02:10 PM
all-mtr-teg's Avatar
Even stock rod bolts can be a bit of a challenge sometimes, try using a penetrating lube, if that doesn't work take them back to the machine shop and ask them to show you a method on how to remove them w/o damaging anything.
Old May 17, 2008 | 05:44 PM
Eddiebx's Avatar
waht u might need is a rod splitter tool.
Old May 17, 2008 | 06:26 PM
TealEG!'s Avatar
Default Re: ARP rod bolts wont let cap come off!! (all-mtr-teg)
Old May 17, 2008 | 07:39 PM
sdr KEL's Avatar
what you do is... put the nut back in about 5 turns.. get a rubber hammer n tap the nutt.. till it comes off..it will break loose
Old May 18, 2008 | 01:32 AM
hybrid2007's Avatar
Default Re: (sdr KEL)
You mean if the rod is installed on a crank right?
Old May 18, 2008 | 06:48 AM
stumpyf4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sdr KEL &raquo;</TD></TR><TR><TD CLASS="quote">what you do is... put the nut back in about 5 turns.. get a rubber hammer n tap the nutt.. till it comes off..it will break loose</TD></TR></TABLE>
That works well if the rods are on the crank.
But this technique can still be used. Clamp the cap in a vice (use soft jaws or rags to protect the rod) with the rod/piston hanging below. Thread the nut on 5 turns or so and hit the nut, alternating hits between the 2 nuts.
Old May 18, 2008 | 08:55 AM
TealEG!'s Avatar
Default Re: (stumpyf4)
Modified by TealEG! at 5:41 PM 6/3/2008
Old May 21, 2008 | 02:52 PM
TealEG!'s Avatar
Default Re: (TealEG!)
cmwalker
24
Jun 3, 2012 05:39 AM
Circuit Star-29
18
Apr 25, 2006 12:17 PM
Toadfart
Nov 14, 2005 09:29 PM
B18EG6
Jun 30, 2004 04:15 PM
turbohf
May 11, 2004 06:30 AM
