!!!!!!!!!!!!!INLINE PRO TURBO MANI'S/WALBRO FUEL PUMPS/SUPERTECH PISTONS AND VALVETRAIN/VALVES!!!!!!
Hey guys, we're a new sponsor on here and we really want to get our name out there. Many in the tri state area know us locally and alot of you guys should know us from this forum. Please contact STEVE@NrgTechParts.com for anything you need. That name is my E-mail AND AIM name.
<U>B-Series</U>
Price Drop!!!!
Stainless Steel T4 $525 Shipped!!! (msrp $599 plus shipping)
Stainless Steel T3 $525 Shipped!!! (msrp $599 plus shipping)
Cast Iron T4 $425 Shipped!!! (msrp $499 plus shipping)
Cast Iron T3 $425 Shipped!!! (msrp $499 plus shipping)
Cast Iron 4 bolt discharge housing $425 Shipped!!! (msrp $499 plus shipping)
<U>K-Series</U>
Cast Iron T3/T4 Dual Drilled $525 Shipped!!! (msrp $599 plus shipping)
<U>F20C S2000</U>
Cast Iron T3 $625 Shipped!!! (msrp $699 plus shipping)
Shipping is free for the lower 48 states only!!!
We have these in stock and ready to ship or pick up!!!
$95 dollars shipped $90 picked up
As some of you may already know SuperTech is the company who produces a lot of the valvetrain components offered by Skunk2racing.
Complete B series valve train sets available for $550!!!! This includes Valves, Valvesprings, and Retainers!!!!
<U>B&K Series Valve Spring/Retainer Package </U>
B series 350 Shipped!!! K Series 400 Shipped!!!
Brand new Supertech Performance Dual Valve Springs and Ti Retainers for any DOHC Vtec Honda/Acura engine. Works in B18c1, B18c5, B17a1, B16a. Excellent performance upgrade for anyone pushing their engines past the stock rev limited or utilizing larger than stock lift and duration camshafts.
Supertech Valve Springs are made with premium Super Clean Chrome Silicone Vanadium Steel alloy for higher performance and durability at high RPMs and better memory.
Computer designed to ensure that wire stress levels do not overpass the limits of stress defined in the diagrams of fatigue for long durability under extreme conditions.
Computer software also allows us to make sure that the harmonics are well under control.
The Titanium Retainers are manufactured with high quality military certified Titanium alloy, CNC machined for a tight fit that will ensure long durability.
<U>B-Series Valve Sets</U>
250 Shipped!!!
DESIGN:
Supertech Performance uses their experience of more than 20 years in the manufacturing of racing valves, do intensive testing and work very closely with many engine builders in order to continuously improve and provide the market with the best possible product for every application.
High flow rates, durability and quality are of great concern to Supertech Performanace.
Note regarding FLAT or DISHED head. Flat is for all motor applications, and will give a slight boost in compression. The Dished head valve is slightly lighter, and used for turbo applications.
MATERIALS:
Supertech Performance manufactures racing valves in many different materials like Stainless Steel, Nimonic, Inconel, Titanium, etc. There are different alloys, heat treatments and coatings used for different applications. For most of the alloys, Supertech Perormance follows the specifications under SAE standard J775.
<U>4 Cylinder Piston sets w/ rings </U>
$490
We have both the front and rear matching skinnies available for purchase. We also have packages available with slicks mounted and balanced for both front and rear skinnys.
<FONT SIZE=""5"">Here is the best pricing around!!! Shipping is available for $10 more!!!</FONT>
<U>Rims only</U>
VPD 13x7.5 pair $295 (fronts)
XPD 15x3.5 pair $305 (skinnies)
Slicks and wheels packages are available. The packages come with the slicks already mounted, balanced, with new valve stems ready to bolt on and race!!!!!!!!
<U>Packages come with M&H Slicks!!! (Mickey Thompson also available.)</U>
22x8x13 package $685
23x8x13 package $699
24.5x8.5x13 package $730
25x8.7x13 package $750
26x8.5x13 package $760
<U>Skinnies</U>
22x3.5x15 skinnies package $645
24.5x3.6x15 skinnies package $655
<U>13x7.5 Drag/Autocross Wheels (pair)</U>
We have all colors available, (Black, Gun Metal, Silver, Gold, and White)
Lenso VPD Racing Wheels. Mostly used in FWD Honda Drag cars but can be used in road racing and autocross applications that also have 4x100 lug pattern. Price is per pair. Make sure you order 2 pairs if needing 4 pcs for all corners. * Will fit 88-00 Civic, 90-00 Integra brakes(exc. ITR calipers) * Fits certain year Miata's, call us for information. * No need for extended wheel studs or special lug nuts. Just bolt on and race.
<U>Skinnies 15x3.5 (pair)</U>
Recommended Tire Size: M&H 22x3.5x15, M&H 24x3.6x15
The design is to match the existing VPD 13" wheel. This lightweight skinny is perfect for FWD Honda, VW, etc. drag cars. The XPD-R can also be fitted for RWD drag cars with skinnies in the front.
$50 Picked Up!!! $55 Shipped!!!
<FONT SIZE=""4"">Many in stock!!!</FONT>
<U>Applications</U>
Honda/Acura B16A/B18C5
D16 (92-2000 SOHC)
B18C
B18A/B18B
H22A
F22-VTEC
ZC/D16A1(DOHC)
K20A2, K20A, K20A3, K20Z1 (RSX, 02-05 Civic SI, CRV))
K20Z3, K24A2 (TSX, Accord, Element, 06-07 Civic SI)
S2000
Toyota Celica GT-S and Matrix
Mitsubishi 90-94 & 95-99 Eclipse turbo, and Lancer Evo
Nissan 350Z & G35, Sentra SER Spec-V, SR20DET (high port)
Hyundai Tiburon V6 and I4
Mazda 90-93 Miata 1.6L, 94-97 Miata 1.8L, 99-up Miata 1.8L
Subaru WRX
Dodge SRT4, 95-00 Neon 2.0L and 2.4L
Details
Hondata have developed a special high temperature insulating gasket which replaces the stock intake gasket. This and bypassing several heat sources significantly reduces the transfer of heat from the head to the intake and incoming air giving you up to 5% more power.
Turbocharged cars often use an aluminum intercooler to cool the air compressed by the turbo. The intake manifold is also made of aluminum but because it is heated by the head from combustion and coolant, works in reverse to an intercooler by heating the intake air by as much as 50° C.
Fact: For every 3.3 °C (5° F) rise in intake temperature, air density drops 1%. The hotter the air, the less fuel the computer injects to compensate for reduced oxygen. HondaLogger datalogging software has enabled us to measure intake air temperature under varied driving conditions.
Around town, testing has shown an average drop of around 10 degrees C which is good for around 3 percent power increase. Remember though that 3 percent power increase is difficult to feel. You'd feel a greater change in performance getting rid of that passenger. In certain conditions a 30° C drop has been measured.
The Honda manifold is heated in up to 5 places. From the head, the interior heating takeoff hose, the cold idle valve, the idle control valve and the throttle body heater. The Heatshield gasket kit contains an insulating gasket, and installation instructions. A race version only version with the thermostat bypass blocked is also available.
The graph above shows the results of installing the Heatshield gasket and bypassing the throttle body heating and idle control valve heating. If you examine a Type R intake manifold you will find that most sources of water heating are removed. Further temperature drops are possible when in addition the interior heating hose is blocked. What the graph shows, is that as you open the throttle, the intake temperature drops slowly as it cools the intake. When you descend a hill with the throttle closed or drive around town on a light throttle the temperature climbs quickly. It takes a good 15-20 seconds for the temperature to drop again when you open the throttle. So if you start your 1/4 mile drag with a hot intake manifold - you are only starting to develop maximum power near the end of the run when the intake has been cooled. The Heatshield gasket kit gives you 4-5% more power immediately by lowering the intake temperature.
SHIPPING IS FREE IN THE 48 STATES!!!!!!!!!!!!!!!!!
LET ME KNOW GUYS!!!!!!!!!!!
Modified by NRGtechParts at 12:01 PM 9/15/2008
<U>B-Series</U>
Price Drop!!!!
<U>K-Series</U>
<U>F20C S2000</U>
250 Shipped!!!
DESIGN:
MATERIALS:
$490
<U>Rims only</U>
<U>Skinnies</U>
<U>Applications</U>
D16 (92-2000 SOHC)
B18C
B18A/B18B
H22A
F22-VTEC
ZC/D16A1(DOHC)
S2000
Subaru WRX
Details
anyone will love the inline pro manifold. especially if switching from a tubular style. the ease of installation is so nice. very nice products. and they also make great power
. bump and PM'd you about a price for lenso's
t3 inline pro will i have any issues using a gt35r turbo? i want to keep the exhuast towards the passenger side. thank you
cant see pm for some reason please email me at miguelmaldonado329@comcast.net thank you
<U>B-Series</U>
Price Drop!!!!
<U>K-Series</U>
<U>F20C S2000</U>
250 Shipped!!!
DESIGN:
MATERIALS:
$390
<U>Rims only</U>
<U>Skinnies</U>
<U>Applications</U>
D16 (92-2000 SOHC)
B18C
B18A/B18B
H22A
F22-VTEC
ZC/D16A1(DOHC)
S2000
Subaru WRX
Details
<U>B-Series</U>
Price Drop!!!!
<U>K-Series</U>
<U>F20C S2000</U>
250 Shipped!!!
DESIGN:
MATERIALS:
$390
<U>Rims only</U>
<U>Skinnies</U>
<U>Applications</U>
D16 (92-2000 SOHC)
B18C
B18A/B18B
H22A
F22-VTEC
ZC/D16A1(DOHC)
S2000
Subaru WRX
Details
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicgsr »</TD></TR><TR><TD CLASS="quote">can you pm me a price for supertech valves,valve springs and retainers shipped to 77901?</TD></TR></TABLE>
pm sent
pm sent
