is there a difference between an obd1 gsr intake manifold compared to an obd2 one?
Old May 17, 2008 | 05:52 AM
thedb63's Avatar
Default is there a difference between an obd1 gsr intake manifold compared to an obd2 one?
i am doing a ls/vtec swap with a gsr head i have everything obd1 except the intake manifold....it is obd2....i have looked for about an hour now trying to find if there is a difference between the two but i dont know for a fact.. the manifold itself looks the same but are there any sensors that are different...if you could help me out that would be great ... thank you in advance
Old May 17, 2008 | 05:55 AM
mn_babyboy's Avatar
somebody help him out.
Old May 17, 2008 | 07:06 AM
thedb63's Avatar
Default Re: (mn_babyboy)
bump
Old May 17, 2008 | 02:08 PM
FuNkDrSpOt's Avatar
Default Re: is there a difference between an obd1 gsr intake manifold compared to an obd2 one? (thedb63)
Sure is. i was going to send a link because it's on a certain DIY in the 92-00 Civic FAQ/DIY page for how to Legalize a jdm motor with the CARB/BAR but they readjusted the links page and now i can't find it.
Old May 17, 2008 | 02:12 PM
all-mtr-teg's Avatar
Im looking at a 95 GSR IM and a 98 GSR IM, I don't see any difference. The only sensors I see are the IAT, EVAP, and the one for the secondary butterflies(forgot what its called) and both models have them all, as well as the evap canister tube on the bottom backside.
I would only imagine a JDM one to be different?
Old May 17, 2008 | 02:20 PM
FuNkDrSpOt's Avatar
Default Re: is there a difference between an obd1 gsr intake manifold compared to an obd2 one? (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Im looking at a 95 GSR IM and a 98 GSR IM, I don't see any difference. The only sensors I see are the IAT, EVAP, and the one for the secondary butterflies(forgot what its called) and both models have them all, as well as the evap canister tube on the bottom backside.
I would only imagine a JDM one to be different?</TD></TR></TABLE>
Maybe then. Maybe it was for the charcoal canister/evap solenoid. I remember it being something about having one less inlet for vacuum.
Old May 17, 2008 | 09:39 PM
thedb63's Avatar
Default Re: is there a difference between an obd1 gsr intake manifold compared to an obd2 one? (FuNkDrSpOt)
so im good to go!!!! thanks guys just thought i would be sure before i start ripping a head off a perfectly good running car and then find out that i need more parts that im not going to get for a bout a nother week...
Old May 26, 2008 | 04:33 AM
thedb63's Avatar
just did the swap and everything worked out...there is two spots that need to be plugged but othere than that there is one solenoid at the top of the manifold that i didnt even use because there was no plug for it so i took it off...runs great!!!!!!!!thank u guys
weaksoN!
Jun 12, 2011 07:45 PM
JDMkid413
Apr 10, 2010 06:16 PM
Mr_Moos
Northwest (Sales)
Jan 20, 2010 04:45 PM
Dang EG
Jul 15, 2004 03:34 PM
