Any DB8 4 Door's with JDM ITR Exhaust?
Old May 16, 2008 | 10:04 PM
4dooritr's Avatar
Default Any DB8 4 Door's with JDM ITR Exhaust?
I'm looking to pick-up new exhaust...
I already have a ported JDM ITR header installed. but my Kteller exhaust is bugging me and never fit right. I also want mycar to be OEM quiet again
Looked on JHPUSA and they have new ITR B-pipe and axle back JDM ITR Muffler but for coupe's..
now from what ive heard the only thing that needs to get modified on that is the tip on the muffler be extended 2-4" or so. is that true?
anyone with real-time experince?
Old May 17, 2008 | 07:17 AM
PACT man's Avatar
Default Re: Any DB8 4 Door's with JDM ITR Exhaust? (4dooritr)
I am running a coupe OEM ITR muffler on my sedan right now and yes the tip needs to be extended, mine is tucked under the bumper a little. I'm pretty sure the B-piping is about 4 inches too short also from the coupes to the sedans, you might need to get that extended also.
The ITR muffler does a great job at quieting the sound while still flowing good, I know that from personal experience. I have DC sports 4-1 header, Megan racing resonated test pipe and custom b-piping with a resonator in it(all 2 1/4") and with the ITR muffler barely is louder than stock. When you take off the muffler it sounds almost as loud as open header though, will easily get me pulled over.
Old May 17, 2008 | 02:02 PM
4dooritr's Avatar
Default Re: Any DB8 4 Door's with JDM ITR Exhaust? (PACT man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACT man &raquo;</TD></TR><TR><TD CLASS="quote">I am running a coupe OEM ITR muffler on my sedan right now and yes the tip needs to be extended, mine is tucked under the bumper a little. I'm pretty sure the B-piping is about 4 inches too short also from the coupes to the sedans, you might need to get that extended also.
The ITR muffler does a great job at quieting the sound while still flowing good, I know that from personal experience. I have DC sports 4-1 header, Megan racing resonated test pipe and custom b-piping with a resonator in it(all 2 1/4") and with the ITR muffler barely is louder than stock. When you take off the muffler it sounds almost as loud as open header though, will easily get me pulled over.</TD></TR></TABLE>
but it all bolts up fine right?
I just want it to line up correctly on the two bend's and over the control arm like stock
Old May 18, 2008 | 04:23 PM
boost'd_crx's Avatar
they have one for the 4drs. (off the 4dr type r)
Old May 18, 2008 | 06:21 PM
WhiteGsrBeater's Avatar
I have the ITR DB8 muffler on my car and it bolts up like stock, you dont need to extend the tip it fits perfectly. A little bit in sound difference but definetly looks better then the stock USDM muffler.
Old May 18, 2008 | 09:04 PM
SuckMyDOHC's Avatar
just look for a JDM DB8 ITR exhaust. I actually have a DB8 ITR b-pipe
Old May 19, 2008 | 07:50 AM
jomama's Avatar
my first choice would be the jdm db8R exhaust. if you can get the dc2 one and make it fit, more power to you. otherwise, i had a comptech unit for my db8 and i loved it.
Old May 20, 2008 | 03:00 AM
4dooritr's Avatar
Default Re: (jomama)
Well you cant get a DB8R exhaust new
I'll just go with the 08 Civic Si Muffler.
Old May 22, 2008 | 01:56 PM
You can find them used if you want used...
aZnjCC
16
Mar 9, 2006 01:50 AM
fkneh
Mar 8, 2006 08:18 AM
JMigs
Apr 8, 2005 12:23 PM
KND
Jan 29, 2004 09:58 PM
texasSI
11
Feb 16, 2003 08:17 PM
