horrible sound
Old May 16, 2008 | 09:00 PM
fatfurious2's Avatar
Default horrible sound
there is a horrible sound coming from my engine. it sounds like metal on metal rubbing. could it be power steering pump? or alternator belt? i dont know...any suggestions would help. I have a 92 LS.
<EDIT>
The noise is a rubbing sound. it sounds like metal on metal rubbing, like from a belt or something. it is on the drivers side. i took it to a shop and the noise went away. so right now the only idea i have is the ac compressor. but my ac works fine and the noise isnt there all the time. for the future What size belt would I have to get to just delete the ac system? is the compressor belt powering anything else like the alternator or the power steering?
thank in advance to all your responses and help
Modified by fatfurious2 at 8:54 PM 5/18/2008
Modified by fatfurious2 at 8:55 PM 5/18/2008
Old May 16, 2008 | 09:09 PM
mr.beeks's Avatar
Default Re: horrible sound (fatfurious2)
sounds like the ac compressor...
Old May 16, 2008 | 09:11 PM
Default Re: horrible sound (mr.beeks)
i was just running it tonight, when i heard it...i wasnt using ac..but what do i know. it goes on and off, and i can hear it when i turn the wheel, but also when im just sitting
Old May 16, 2008 | 09:14 PM
mr.beeks's Avatar
did u check steering fluid level also are u using honda power steering fluid
Old May 16, 2008 | 09:15 PM
i havent done anything yet, its 1:15am here, but i will check in the morning.
oh and i think i have honda fluid
Old May 16, 2008 | 09:19 PM
mr.beeks's Avatar
same time here buddy northeast...
mostlikely is your ac compressor. do you smell like a brake is burning when you open hood?
Old May 16, 2008 | 09:20 PM
im not sure, i was focusing on listening
Old May 16, 2008 | 09:24 PM
mr.beeks's Avatar
im me in the morning
Old May 16, 2008 | 09:25 PM
will do
Old May 17, 2008 | 01:46 AM
SleeperGSR's Avatar
I have a similar noise, although i think it may be a bearing in one of the pulleys. I think mine is comming from the alternator? I can't really tell. I think it could also be the timing belt tensioner? Would either of these produce a bad noise?
Old May 17, 2008 | 06:44 AM
mr.beeks's Avatar
Default Re: horrible sound (SleeperGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">I have a similar noise, although i think it may be a bearing in one of the pulleys. I think mine is comming from the alternator? I can't really tell. I think it could also be the timing belt tensioner? Would either of these produce a bad noise?</TD></TR></TABLE>
alternator will fail period
same w timming tension pulley the thing will just snap
Old May 17, 2008 | 07:23 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatfurious2 &raquo;</TD></TR><TR><TD CLASS="quote">i was just running it tonight, when i heard it...i wasnt using ac..but what do i know. it goes on and off, and i can hear it when i turn the wheel, but also when im just sitting</TD></TR></TABLE>
Check the belt tension on you PS pump. If turning the wheel increases the noise, the PS pump is the most likely suspect. You can lift the hood and have a friend turn the wheel to diagnose the noise as well.
Old May 17, 2008 | 09:13 AM
Default Re: horrible sound (Dogginator)
so i took it to a local car shop to have them listen to it..and the noise went away. the guys there said it might be the ac compressor. but since the noise went away im just gonna leave it. i dont even use the ac anyways.. but for future knowledge, if i take out the ac system, what kind of belt would i have to get to still power the other things that are with the compressor?
Old May 17, 2008 | 09:58 AM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatfurious2 &raquo;</TD></TR><TR><TD CLASS="quote">so i took it to a local car shop to have them listen to it..and the noise went away. the guys there said it might be the ac compressor. but since the noise went away im just gonna leave it. i dont even use the ac anyways.. but for future knowledge, if i take out the ac system, what kind of belt would i have to get to still power the other things that are with the compressor?</TD></TR></TABLE>
Take the belt off and see if it still does it.
Maybe I'm being stupid and didnt' see this info, but if i were you what I would do is edit your ORIGINAL POST to include where exactly in the engine bay the sound is coming from, when exactly it occurs and if you can re-create the sound with certain actions. Always update the original post to include new info so you dont' get the same recommendation 40 times in a row.
For instance, i, too had a a metal on metal sound but it was a rattling sound coming from my front drivers' side. I found out it was my dust shield on my
Old May 17, 2008 | 02:04 PM
Teg LS's Avatar
is it a rubbing sound or more of a rattling? if its rattling its probably your heat shield because integras are known to have a shaky shield
Old May 18, 2008 | 07:56 PM
Old May 18, 2008 | 08:04 PM
x3kevin's Avatar
find out yet?
Old May 18, 2008 | 08:08 PM
Default Re: horrible sound (x3kevin)
not really, the noise went away so im just gonna leave it for now..
I also need to find out what else is powered by the belt going to the ac compressor, like my alternator or power steering, and what size belt i need to get if i decide to take the ac off..
eldog80
Mar 2, 2012 11:56 AM
october_red
Nov 22, 2008 10:07 AM
Mandeep
Jul 9, 2005 11:27 AM
THE94GSR
Oct 29, 2003 10:35 AM
oMek
Oct 26, 2003 10:39 AM
