Compression test: big cams
Old May 16, 2008 | 06:50 PM
lude98SH's Avatar
Default Compression test: big cams
I know pretty much everyone on here has at one time or another heard " Running bigger cams bleeds off compression". My question is why does it bleed off compression ? Is it the added duration that causes this to happen ? I have also read that this is a big myth. Could someone clear this common saying up ?
Old May 16, 2008 | 09:21 PM
Top Ramen's Avatar
Default Re: Compression test: big cams (lude98SH)
Simple version:
If you have a lot of duration, when the piston starts up on the compression stroke the exhaust valves are still open a bit, so some of the charge is pushed out, so compression bleeds out a bit. With really big cams, it is almost as if the piston is chasing the valves closed.
Old May 17, 2008 | 02:17 PM
lude98SH's Avatar
Default Re: Compression test: big cams (Top Ramen)
good explaination, it makes sense
Old May 17, 2008 | 02:31 PM
DonF's Avatar
But not as much if you have a VTEC motor. Have you ever figured out you have more cam lobes than a Chevy? Do not even try to figure ont K motors, with VTEC and adj. cam timing.
Old May 17, 2008 | 02:42 PM
Combustion Contraption's Avatar
But does it bleed compression... or vacuum?
Old May 17, 2008 | 06:09 PM
bluedlude's Avatar
Default Re: (Combustion Contraption)
arent the two directly related?
Old May 17, 2008 | 06:15 PM
Yes, but regardless of how big the cams are, the valves are still closed on the compression stroke. So youre not bleeding off compression, youre bleeding off vacuum.
Old May 17, 2008 | 06:17 PM
bluedlude's Avatar
yeah, thats what i meant. but you could say you are bleeding off compression because you are bleeding off vacuum. but im taking your words in the most literal sense
integra123
May 10, 2006 01:05 PM
fsp31
11
Jun 7, 2005 05:18 AM
silversly
Dec 18, 2004 08:02 AM
bxsi
Apr 2, 2004 05:42 AM
HX_Guy
Aug 22, 2001 02:00 PM
