? about Taillights ap2 to ap1
. did you buy them with the harnesses? im sure you can splice the ap1 harness in and make it work but I havent done it so I cant realy tell you how to do it. Just got take it apart and try it. It shouldnt be too hard just use comon sence.
You will need to do some cutting in the rear to install the lights. Hardtopguy.com sells the kit needed for the retrofit.
You will need to modify the harness from the AP2 to work with the AP1.
jdmekrsi
Mar 14, 2005 02:12 PM
