Son's CRX Brake Problem
My 20 year old son has a 90 CRX DX that had a brake master cyl. go bad and after replacing it the left front and right rear bleeders worked great. Right front and left rear wont hardly flow much at all. Brake pedal falls almost to floor after bleeding all four and driving.
Should I take brake porpotioning valve out and chuck it against a tree or get a new son ????
Did you bend bleed the master cylinder before installing it on the car??
Also are you making sure that reservoir is FULL the entire bleeding process??
You only need to open the bleeder maybe a half turn!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">Did you bend bleed the master cylinder before installing it on the car??</TD></TR></TABLE>
thats what i was gonna say. you need to make sure that you bench bleed the mc and then install it.
msinsky14
May 21, 2007 07:31 PM
