Suspension squeaks over bumps
Old May 16, 2008 | 10:28 AM
ac_attak's Avatar
Default Suspension squeaks over bumps
When i go over bumps my front suspension sounds like a squeaky mattress. I also noticed that when i am stopped, if i turn the steering wheel back and forth i get the same squeaking sound coming from somewhere around the 2 front wheels. Anybody know what the likely cause would be?
Old May 16, 2008 | 10:30 AM
SkaiWu's Avatar
i dunno people say bushings or the shocks are worn
mine sounds like a old wooden door creaking like in those haunted houses n **** eeeeeerrrkkk
i think ill just have them rebuilt when i get a summer job and get myself some GC coilover sleeves whileim at it
Old May 16, 2008 | 11:20 AM
CleanTeg's Avatar
Mine did this and it was an easy fix. Jack the front of the car up and spray the upper a arm bushings with WD-40. It's the two bushings that are often replaced as a camber kit. Spraying those down with WD-40 fixed my problem. While you're under there you might as well hit all the rubber bushings with a little lube just in case.
Old May 16, 2008 | 11:28 AM
super jdm yo's Avatar
Default Re: (CleanTeg)
my buddy's mom's car did this. though she had a 87 accord, but yeah. like we used to be able to hear him coming from the squeaking down the road. and at red lights he used to turn the wheel so it would sound like the beginning of that one song "some cut" in front of people at the cross walk. we really didn't fix it, just left it the way it was because it was funny.
Old May 16, 2008 | 07:42 PM
SkaiWu's Avatar
LOLOLL SOMECUT
werrt eern werrt eern werrt eern
damn is it that loud?
anyways is wd40 a TEMP fix or how long did it last you
Old May 17, 2008 | 08:21 AM
jwrape's Avatar
Default Re: (SkaiWu)
I would use a silicone spray over WD40. WD40 will attract more dirt to the bushings wearing them out even further.
Which ever you use, wipe off excess spray to keep the dust and dirt from collecting on the sprayed parts.
Old May 17, 2008 | 08:35 AM
Jdm_jay's Avatar
Default Re: Suspension squeaks over bumps (ac_attak)
more then likely bushings look into some enery suspension bushings.
Old May 17, 2008 | 10:37 AM
ac_attak's Avatar
Default Re: Suspension squeaks over bumps (Jdm_jay)
Weird thing is today its 22 degrees celcius out and its not squeaking. But all month the temp. has not risen above 5 celcius and it was squeaking pretty bad in those temperatures.
Old Aug 22, 2008 | 07:21 AM
kdubb03's Avatar
mine does the exact same thing...since WD-40 or silicone spray is only a temp fix...what are some good suspension bushings out there?
Old Aug 22, 2008 | 07:41 AM
jonshonda's Avatar
Community Builder
There is a good chance its your swaybar bushings!! Those tend to dry out and crack!!
Old Aug 22, 2008 | 12:16 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm_jay &raquo;</TD></TR><TR><TD CLASS="quote">more then likely bushings look into some enery suspension bushings.</TD></TR></TABLE>
haha then it will squeak even more!!! Polyurethane will also dry out and crumble in 2-3 years if you don't keep them greased ALL the time. Rubber bushings do not have this problem.
If it's squeaking/creaking when turning the wheels, it's most likely a ball joint. I had a bad lower left ball joint that made a noise when turning the wheel.
But my upper A-arm bushings are also squeaking, and they're only about a year old (installed new OEM replacement A-arms w/ bushings and ball joints last year). I may try some silicone spray on them or something.
THE M4CHIN3
Mar 17, 2014 10:22 AM
meangreenEG
Aug 31, 2007 11:04 AM
lke2drvgsr
Oct 5, 2003 06:01 PM
lotus
Oct 1, 2003 06:35 PM
mattymatt
Jun 9, 2002 02:16 PM
