intersting info on skunk2 stage 2 cams i like to share!!!!!!
Old May 16, 2008 | 08:02 AM
The Tea-father's Avatar
Default intersting info on skunk2 stage 2 cams i like to share!!!!!!
My other time attack Dc2 for the street class
PRC type manifold thanks for jermey
Rcrew version 2 header soon will change to skunk2 swap header good for a few HP
BDL fuel rail and 70mm TB thanks to carlos from BDL
New steering wheel to match my bucket seat. added greddy oil pressure and water temp gauges
Version super low rail with bucket
Dyno from last night 289hp
Spec.
K24 crv block balanced and assembly by "Mario built" from skunk2
K20a2 head unport with skunk2 valves, valve springs and retainers 3 angles valve job
Custom 12.5 weisco pistons skunk2 spec with forged I beam rods skunk2 spec
Skunk2 stage 2 cams with exhaust cam gear
Rcrew header with 3" exhaust . soon to be all skunk2
custom 3" cold air intake
BDL 70mm tb port match to prc manifold
440cc Rc injectors
Hondata k pro thanks to Javier
The motor has 24 miles on it when we dyno it last night, rings are probably not totally seals yet. As you can see on the dyno, the skunk2 stage 2 cam work great with stock unport head. The prc aka type R manifold is not as bad as most people think? I think 300hp is very possible with stock head The exhaust cam gear is retarded -3 degrees and the vtc is at 40 degrees. This is the main reason to have custom pistons made, it allow a lot more pistons to valves clearance. Most of us don't run more then 30 degrees vtc because we worry about it tap out I plan to back to church with a RBC manifold and a little more aggress cam angles see if i can reach 300hp with stock head
Old May 16, 2008 | 09:00 AM
MikeSarr_GSR's Avatar
Default Re: intersting info on skunk2 stage 2 cams i like to share!!!!!! (The Tea-father)
awesome looking forward to your update, the car must be awesome on the track!
Old May 16, 2008 | 09:11 AM
FST GSR 1's Avatar
I would want to move that upper radiator hose off the intake inlet tube.
Nice numbers!
Old May 17, 2008 | 11:34 AM
!LL W!LL's Avatar
no soy maricon!
Default Re: (FST GSR 1)
good **** loi!
skunk 2
Old May 17, 2008 | 11:42 AM
mar778c's Avatar
Community Builder
Community Influencer
Hella nice. I mean everything. The motor, car, steering wheel, etc.
I can't wait for the day the 07 si is tuneable.
Old May 17, 2008 | 05:54 PM
grjp1988's Avatar
Who makes that radiator cooler?
Old May 17, 2008 | 07:38 PM
Dat1BVtecN's Avatar
numbers look great!
Old May 17, 2008 | 09:06 PM
h22crxpwr's Avatar
Default Re: intersting info on skunk2 stage 2 cams i like to share!!!!!! (Dat1BVtecN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat1BVtecN &raquo;</TD></TR><TR><TD CLASS="quote">numbers look great! </TD></TR></TABLE>
Old May 18, 2008 | 09:34 AM
f@sth@tch89's Avatar
Default Re: intersting info on skunk2 stage 2 cams i like to share!!!!!! (h22crxpwr)
one clean looking car. niice dyno numbers...
if you get 300 hp on an unported head, what will the hp numbers be like once you port the head and add bigger cams?
Old May 18, 2008 | 11:40 AM
.dave's Avatar
i HAS questions ?
Default Re: intersting info on skunk2 stage 2 cams i like to share!!!!!! (f@sth@tch89)
Nice setup.
Do you have any more information on the Skunk2 header?
Old May 18, 2008 | 01:17 PM
Shawn C's Avatar
In The Garage
very nice
Old May 19, 2008 | 10:26 AM
Default Re: intersting info on skunk2 stage 2 cams i like to share!!!!!! (.dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .dave &raquo;</TD></TR><TR><TD CLASS="quote">Nice setup.
Do you have any more information on the Skunk2 header?</TD></TR></TABLE>
according to Tony maybe a month or two away
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f@sth@tch89 &raquo;</TD></TR><TR><TD CLASS="quote">one clean looking car. niice dyno numbers...
if you get 300 hp on an unported head, what will the hp numbers be like once you port the head and add bigger cams?</TD></TR></TABLE>
i'll find out soon with the other motor we are working on. ported head, stage 3 cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grjp1988 &raquo;</TD></TR><TR><TD CLASS="quote">Who makes that radiator cooler?</TD></TR></TABLE>
cooling plate? Greddy
Old May 19, 2008 | 12:17 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Tea-father &raquo;</TD></TR><TR><TD CLASS="quote">according to Tony maybe a month or two away </TD></TR></TABLE>
Damn, I'll probably need one before then.
Do you know if they'll have a couple different headers, or just one?
Old May 19, 2008 | 01:23 PM
GUILOTINE's Avatar
Kill Gil
Sportcar and Skunk2 holding it down for Socal
Old May 19, 2008 | 02:16 PM
Skunk2Tony's Avatar
Do you know if they'll have a couple different headers, or just one?</TD></TR></TABLE>
It will just be one K swap header
Old May 19, 2008 | 09:55 PM
Default Re: intersting info on skunk2 stage 2 cams i like to share!!!!!! (Skunk2Tony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2Tony &raquo;</TD></TR><TR><TD CLASS="quote">
It will just be one K swap header</TD></TR></TABLE>
Old May 20, 2008 | 12:39 AM
spoonhatchblack's Avatar
Props 2 Shawn 4 his Mad Skills...
0bd1_Kanobe
Sep 2, 2008 02:11 PM
robboostgsr
Mar 6, 2005 08:42 AM
10000rpm
Oct 31, 2004 01:59 AM
10K2HVN
Aug 14, 2003 01:57 PM
Richard.
Mar 14, 2003 03:48 PM
