Tucking tires???how?
Old May 16, 2008 | 07:50 AM
jewpont's Avatar
Default Tucking tires???how?
Well i just installed my omni power coil over sleeves with skunk2 sport shocks (which i already had). And i soon realized that i rub when turning left or right most of the time. i have a 98 civic with 16" track r's and a 205/45 tire.im not even slammed or anything i just adjusted the coil overs so that the fender is just above the tire, which all in all is probably a 2 1/2"-3" drop from stock.
i was wondering how all those people who are tucking tire get their cars to allow this. im guessing they roll their fenders, but what about the rubbing on the inside on the tires when turning? Is there really any way to stay "slammed" with out rubbing? thanks
Old May 16, 2008 | 07:51 AM
chimmike's Avatar
Default Re: Tucking tires???how? (jewpont)
no, there's not.
that's why slamming sucks. That, and you lose tons of suspension travel, meaning your handling has gone to bunk.
Old May 16, 2008 | 07:53 AM
jewpont's Avatar
leaving handling out is there anyway?
Old May 16, 2008 | 08:06 AM
h2b_sedan's Avatar
Default Re: (jewpont)
slammed cars rule...just keep on pulling on your fender until it stops. or just keep driving it till it stops...
Old May 16, 2008 | 08:08 AM
albertaEK's Avatar
If you run wheels with a close to stock offset, cut/modify your fender liners and fenders, then you can run slammed with no rubbing. Or you could try to always drive in a straight line
Old May 16, 2008 | 08:16 AM
chimmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jewpont &raquo;</TD></TR><TR><TD CLASS="quote">leaving handling out is there anyway?</TD></TR></TABLE>
Say again in English please?
Old May 16, 2008 | 09:51 AM
jewpont's Avatar
Default Re: (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">
Say again in English please?</TD></TR></TABLE>forgetting how it makes the car handle, is it possible? thats what i was saying
Old May 16, 2008 | 10:22 AM
chimmike's Avatar
Different offset wheels, narrower tires, and extending the fenders are about the only ways I can see it happening.
IMO it's dumb.
Old May 16, 2008 | 10:37 AM
Zaraki's Avatar
To be slammed, you need the following.
1) Stiff springs matched with the proper damper
2) Roll your fenders
3) Remove fender liner
I'm tucking my tires by about an inch. 16'' wheels, 205/45/16 tires
Lowered on GC/Koni
Old May 16, 2008 | 10:48 AM
BEE1's Avatar
Default Re: Tucking tires???how? (Zaraki)
try removing the fender liners if that helps
Old May 16, 2008 | 11:14 AM
jewpont's Avatar
Default Re: Tucking tires???how? (BEE1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEE1 &raquo;</TD></TR><TR><TD CLASS="quote">try removing the fender liners if that helps</TD></TR></TABLE>is there any disadvantage of doing this?
Old May 16, 2008 | 11:23 AM
chimmike's Avatar
you get all kinds of nasty road crap on the metal parts inside the fenders.
Old May 16, 2008 | 11:25 AM
STDClayton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jewpont &raquo;</TD></TR><TR><TD CLASS="quote">is there any disadvantage of doing this?</TD></TR></TABLE>
Disadvantage: Dirt all in your fenders/door jambs/engine bay.
Advantage: No more tire rubbing on them.
I'd leave them in and let them rub away where necessary.
Old May 16, 2008 | 12:19 PM
Forcefedvtec's Avatar
I took out the liners and slammed the front where the whole tire was tucked with steelies....the ride sucked so i lifted it back up
Old May 16, 2008 | 01:02 PM
spanishfly's Avatar
Default Re: (Forcefedvtec)
rock a 205/40 and roll your fenders...
Old May 16, 2008 | 01:10 PM
raidacaipo's Avatar
you get a front camber kit.. it allows you to set the tires to go in or out.. I would set it to go in.. then u bring it to get an allignment.. they adjust the bottom part so that the tires go in also.. ull notice that when u adjust the camber kit for the first time on the front that when u drive it will feel as though ur gonna crash.. be careful driving to an allignment shop..
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">Different offset wheels, narrower tires, and extending the fenders are about the only ways I can see it happening.
IMO it's dumb. </TD></TR></TABLE>
i'm slammed roughly 2.5inchs or so all around and i hardly bottom out. My suspension runs fine.
To the OP, if your looking to slam your ride, research some more. It can be done without sacrificing too much comfort or $$$.
Old May 16, 2008 | 03:36 PM
user 98292739's Avatar
ummm wtf there is so much false information here. If you dont know what you are talking about or has NEVER experienced thigns please dont give up information you heard about.
I run D2 36 way adjustable coilovers...you wont lose suspension travel with short body shocks...
205/50/15
15 inch grids
i didnt modify anything, i didnt roll my fenders, i dont rub. im tucking 2 inchs in the front and 1 in the rear.
Old May 16, 2008 | 07:12 PM
mikeycivic's Avatar
Default Re: (The Lobster)
negative camber will help. Do -1--1.5 and get the toe set to zero at the alignment shop.
Old May 17, 2008 | 04:53 PM
jewpont's Avatar
i noticed the other day that a seam inside the fender, is cutting into my tire.
Old May 17, 2008 | 04:55 PM
cashkeith's Avatar
13in steelies lol
Old May 17, 2008 | 05:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jewpont &raquo;</TD></TR><TR><TD CLASS="quote">i noticed the other day that a seam inside the fender, is cutting into my tire.</TD></TR></TABLE>
oh snap...ok i did modify mine some what.
i grinded that seam down the front two.
it also did cut the hell out of my tire, but not no more
Old May 17, 2008 | 05:43 PM
RagnarX's Avatar
What offset on those rims Lobster?
Old May 17, 2008 | 05:46 PM
jewpont's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">
it also did cut the hell out of my tire, but not no more</TD></TR></TABLE>i was thinking of either grinding it or bending it with a huge hammer
Old May 17, 2008 | 05:55 PM
Default Re: (RagnarX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagnarX &raquo;</TD></TR><TR><TD CLASS="quote">What offset on those rims Lobster?</TD></TR></TABLE>
+35 i dont remember i got these rims 3 years ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jewpont &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking of either grinding it or bending it with a huge hammer</TD></TR></TABLE>
i just took an air grinder and went at it.
