How can I identify a set of brakes
Old May 16, 2008 | 06:36 AM
Wikedeye's Avatar
Default How can I identify a set of brakes
I am trying to buy a rear disc set up from a teg for my 93 civic dx coupe. Is there a way to verify that the parts are correct. I cant see what they came off of because they are already off. Are there any part numbers to look for or something.
Old May 16, 2008 | 07:10 AM
EL Vap133's Avatar
Default Re: How can I identify a set of brakes (Wikedeye)
Do they have e-brake cables attached to it? The e-brake cables have part numbers to distinguish the difference. Other than the e-brake cables, all rear disc brakes are the same as far as 92-00 Civic, 94-01 Integra, 90-91 CRX Si, Del Sol Si.
Old May 16, 2008 | 07:34 AM
Wikedeye's Avatar
Default Re: How can I identify a set of brakes (EL Vap133)
Ok so worst case senerio I have to get new cables...Thats not a big deal.
Old May 16, 2008 | 09:30 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wikedeye &raquo;</TD></TR><TR><TD CLASS="quote">Ok so worst case senerio I have to get new cables...Thats not a big deal. </TD></TR></TABLE>
Yes, the trailing arms are the same. Also check the trailing arm bushings to see if they need to be replaced or not.
Old May 17, 2008 | 11:25 PM
evndrkr's Avatar
same for the wheel bearings, rotors and brake lines. check the equipment like hes overcharging you.
asianflava
Dec 8, 2008 11:14 AM
91efsikevs
Suspension & Brakes
Dec 1, 2008 11:55 PM
littlebill
10
Jun 11, 2007 04:55 PM
sightless
Dec 27, 2004 08:01 PM
Canadian Hybrid
Oct 28, 2001 05:04 AM
