ZER0 oil pressure. and no voltage to plugs?
Old May 16, 2008 | 12:43 AM
BB1LOViN's Avatar
Default ZER0 oil pressure. and no voltage to plugs?
my h22a1 has been in limp mode for some time and i finally got an oil gauge and tested my car. the manual says that at 5000rpm the gauge should read 57psi. when i tried it, the gauge showed 0 zero psi.
my uncle whos a mechanic told me to quickly start up the car and turn it off asap,(without the oil pressure gauge plugged in) just to see how the oil flows out. and it simply leakedout, instead of squirting out with pressure.
also another problem is, there isnt enough voltage (12v) going to one of the plugs/wires. not sure what it was but i remember it was a grey plug and it need 12v but i had like 1.xx volts only
any idea what my possible problem might be? i dont want to get another ecu until i know 100% sure that thats the problem. Also i get no check engine lights or anything. just no vtec and 6500 rev limiter. ALSO the car feels soo sluggish
Old May 16, 2008 | 01:49 AM
BlackCatt's Avatar
Default Re: ZER0 oil pressure. and no voltage to plugs? (BB1LOViN)
Not sure about oil pressure prob: maybe a blockage somewhere?. Are your leads in good condition, if they are then most likely ecu like you think. Dont know if this helps at all but goodluck
Old May 18, 2008 | 11:52 PM
BB1LOViN's Avatar
Default Re: ZER0 oil pressure. and no voltage to plugs? (BlackCatt)
thanks for the post. the problem is i dont know any shops thatll let me TEST a new ecu to see if it fixes the problem BEFORE i buy it from them.
also these usdm p13s are too hard to come by.
Old May 19, 2008 | 12:00 AM
no1knows908's Avatar
See if there are any H-T members in your area, where are you located?
Old May 21, 2008 | 12:48 AM
BB1LOViN's Avatar
Default Re: ZER0 oil pressure. and no voltage to plugs? (no1knows908)
located around SOCAL
Old May 21, 2008 | 09:48 AM
Saosinx's Avatar
i have a usdm p13 obd1.. for sale.
Old May 21, 2008 | 12:20 PM
BB1LOViN's Avatar
Default Re: ZER0 oil pressure. and no voltage to plugs? (Saosinx)
how much will you sell it shipped to 90031? whats the last known condition of it?
Old May 21, 2008 | 12:38 PM
Saosinx's Avatar
i just pulled it out of my 4th gen. i have had it in there for over a year, and put it in there when i dropped my jdm h22a swap from HMO. i just got a chipped p28 from phearable and i'm about to buy neptune RTP, so i have no need for it.
Old May 21, 2008 | 12:51 PM
Saosinx's Avatar
Looks like it will be just shy of $17.
Old May 23, 2008 | 06:58 PM
BB1LOViN's Avatar
great bro iam interested. but i have no idea how i can purchase it online from you.
hopefully your ecu can save my h22 haha anyway you can save it for me to buy?
aavtec
Jan 19, 2013 10:09 PM
BlueZXR
Acura NSX
Dec 23, 2012 06:55 AM
superhatchbackbros
Jul 28, 2006 05:47 PM
betsuni
Jan 12, 2006 07:21 AM
