ap1 wheels
Will the Honda s2000 ap1 wheels fit on the 05 rsx with no rubbing issue? I know for sure 4 front ap1 wheels will fit but not sure of the rear. Please help me out. Thanks
just a thought, but I know that on ep3's that fitting 225's requires rolling the rears but not the fronts, so maybe you could switch the ap1 wheels and use the rears on the front and vice versa, even run a staggered a set-up to allow our rear to rotate more, thats what im doing, just not with ap1 wheels, just getting rota's or sportmax and running 225's up front and 215's in the back, what exactly is the offset and rim width on the ap1 wheels?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob #2 »</TD></TR><TR><TD CLASS="quote">what exactly is the offset and rim width on the ap1 wheels?</TD></TR></TABLE>
AP1 OEM US wheel spec same as JDM BBS 6 spoke rim (lighter)
16X6.5 +55 front
16X7.5 +65 rear
16X6.5 +55 front
16X7.5 +65 rear
jesus thats one hell of an offset, I didn't know they were that positive, you could always get extended studs and run spacers......there is a member on ephatch.com that is using this set-up and it looks awesome, ill go get it here shortly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">how heavy are the the AP1 wheels?</TD></TR></TABLE>
their heavy, might as well go with rotas for performance. but if you really want the s2k wheel looks then heres for you.
AP1 USDM cast 16's
front 17.5 lbs
rear 18.6 lbs
AP1 JDM BBS forge 16's
front 13.3 lbs
rear 14.3 lbs
AP2 USDM cast 17's
front 17.6 lbs
rear 20.5 lbs
AP1 USDM cast 16's
front 17.5 lbs
rear 18.6 lbs
front 13.3 lbs
rear 14.3 lbs
AP2 USDM cast 17's
front 17.6 lbs
rear 20.5 lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">what do the jdm bbs look like?</TD></TR></TABLE>
here they are.
here they are.
I vote on the stock rims look better on the car.... With the money and time you spent looking for a set of the AP1 wheels you could have some rotas...
