can i add cruise control to my dx?
Here's an installation on an Integra to show you what's involved.
http://www.sandmracing.com/m_e....html
Here is the kit for the Honda.. Its made by rostra.. A friend of mine used to work at a speedo shop and this is the brand they always installed.
http://cgi.ebay.com/ebaymotors...06688
No affiliation with the company selling the above kit.. that just happens to be where I'm going to buy mine from once I verify that the DX and HX use the same throttle adapter.
~Mark
~Mark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic4nick »</TD></TR><TR><TD CLASS="quote">well, people said that the oem ones tend to not work properly and will get stuck cruising and stuff...</TD></TR></TABLE>
I have never heard of a recall to service bulletin on the cruise control.
I have the factory cruise control ('98 EX coupe) and have NEVER ad any issue in the least with it.
I have a vacuum actuated aftermarket cruise control on my 92 VX.
My cruise control works fine. If you decide to buy one however, you will need to install a separate vacuum canister to store engine vacuum. The tiny 1.5L engine on my VX does not have adequate vacuum at mid throttle so it slows down uphill without stored vacuum. I added the vacuum canister myself. Easy to do and costs only $15.
Motorcycle engines have the same problem with climbing hills with cruise control because of the small displacement on some models - 750 cc engines for example.
Try to find a vacuum actuated cruise control, they are more reasonably priced and do the job just as well. Installation isn't easy but it's definitely worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic4nick »</TD></TR><TR><TD CLASS="quote">im talking about when u add it on...not when it comes stock on the car...</TD></TR></TABLE>
Installation error then. It has nothing to do with it being OEM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadziasman »</TD></TR><TR><TD CLASS="quote">I have a vacuum actuated aftermarket cruise control on my 92 VX.
Try to find a vacuum actuated cruise control, they are more reasonably priced and do the job just as well. Installation isn't easy but it's definitely worth it.</TD></TR></TABLE>
sounds good thanks for the info
I have the exact same issue. I would like to add cruise control to my 92 civic DX, I bought the car because it only had 90k original miles... and thought I could live without it. Well I do drive long distances and it does get annoying..
About how much do the kits run, and how much is installation typically? And is it really unsafe? I am definatley watching this thread.
theres nothing unsafe about it, as long as the installer does all of the throttle linkage connections right. i dont remember how much the unit sells for, but we used to get about $100 for labor. the good thing about the electric rostra is the fact that you dont have to use a clutch switch on a manual car. it has a tach wire you hook up and kills the cruise as soon as tach starts to rise abruptly. does it so quick you dont even notice.
From what I read from Rostra.. I need the throttle plate to hook up the cable from the cruise.. It doesn't come with the adapter I need for my HX (at least thats what it looks like and they make an adpater for the 1.6L civic and show it needs the plate).
I like the RF module becuase I can put it where the factory cruise would normally go.. I didn't see any way to install the stalk to my HX. If you know of a pic that shows how you use the Stalk method with a civic, please post the link as that would be cheaper than the RF module and I don't want the box with the buttons..
~Mark
~Mark
ive put on hundreds and never used a throttle plate. i used the hardeware that comes with it. but its your money. if they make a bolt on piece for easy install then by all means buy it. as far as the stalk you just drill a hole in the side of the steering column cover and mount it. it protrudes into the inside of the plastic maybe a 1/4". it can be mounted below your turn signal stalk and out of the way of the tilt steering lever with no problems. but ive done this numerous times and its a very cookie cutter install when i do them.
i have a vaccum actuated aftermarket cruise on my 96 CX, it came with the car when i bought it, i dont know what brand it it, but it works fine, no problems except it doesnt have a cluth switch, so i usually have to turn it off before downshifting to climb a steep hill, damn i hate my long *** tranny!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_wanabe »</TD></TR><TR><TD CLASS="quote">i have a vaccum actuated aftermarket cruise on my 96 CX, it came with the car when i bought it, i dont know what brand it it, but it works fine, no problems except it doesnt have a cluth switch, so i usually have to turn it off before downshifting to climb a steep hill, damn i hate my long *** tranny!</TD></TR></TABLE> probably an scs/frigette.
could I in theory take the cruise control off of my 92 lx, and put it on my 92 dx?.....I have 2 cars and one of them is old. I probably wouldnt do this(would want cruise control in both cars) but I assume its possible right?
