Needed parts for re-install of cyl. head?
Old Jul 14, 2002 | 10:09 PM
Rhetoric's Avatar
Default Needed parts for re-install of cyl. head?
So far I have center o-ring gasket, head/in/ex gasket. I am planning to re use my cylinder head plug and cam seals. Anything I forgot?
Oh yeah, is it truly necessary to replace head bolts?
I dont remove/install heads frequently so just wondering what else I may need to look out for.
Thanks.
Old Jul 14, 2002 | 10:21 PM
IN VTEC's Avatar
Default Re: Needed parts for re-install of cyl. head? (G S R)
I think it's perfectly safe to reuse the head bolts at least once. Even teh service manuals never say to replace them. Most builders just have a natural tendency to do this, especially on turbo blocks, in which case they switch to using ARP headstuds w/ nuts instead of the bolts.
On high mileage motors, you wanna replace the valve seals while you've got the head off.
Valve cover gasket & spark plug gaskets you might want to replace, but unless they're torn, they don't leak if you tighten up the valve cover nuts properly.
Old Jul 15, 2002 | 01:00 AM
sgT's Avatar
sgT
Default Re: Needed parts for re-install of cyl. head? (IN VTEC)
I NEVER reuse head bolts, unlesss im at the track and i have no other recourse
Old Jul 15, 2002 | 06:01 AM
IN VTEC's Avatar
Default Re: Needed parts for re-install of cyl. head? (sgT)
Is there a bad experience that goes along with this? Usually you got a good story to tell with every rule of engine building.
Old Jul 15, 2002 | 07:27 AM
Darin D.'s Avatar
I reused the stock head bolts 4 times before. The 4th time was on my turbo motor...10k miles later, no problems still. I'm sure it's probably better to replace them, but that's a lot of money you can save by reusing them.
Old Jul 15, 2002 | 08:39 AM
sgT's Avatar
sgT
I've had the head gasket not seal once.
I've also had them back out after a few hundred miles.
I've also had no problems reusing.
But its a gamble when reusing them and when using new bolts I have never
had any problems.
Old Jul 15, 2002 | 01:58 PM
IN VTEC's Avatar
mucho mucho gracios
JamesB1985
Mar 5, 2013 06:58 AM
twocross
Feb 23, 2011 03:07 PM
FK00GSR
Aug 31, 2007 01:50 PM
petrv
Apr 12, 2004 12:30 PM
Austin
Jan 31, 2002 10:17 AM
