Transmission compatibility for 89 CRX HF w/ D15B2
Old May 15, 2008 | 01:31 PM
ADAMnQuickRDX's Avatar
Default Transmission compatibility for 89 CRX HF w/ D15B2
I am considering buying an 89 crx HF, seller says it has a D15B2, not sure if that's the original engine or not.....problem is it needs a new transmission (5spd), can someone please let me know what vehicles i can source a transmission from? model/yr please.
Thanks alot!
-Adam
Old May 15, 2008 | 02:26 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Transmission compatibility for 89 CRX HF w/ D15B2 (ADAMnQuickRDX)
any 88-91 transmission will work but the combo of flywheel and clutch will change with your choice of transmission year.
the 88 had a 190mm flywheel and 21 spline clutch
the 89 had a 200mm flywheel and 20 spline clutch
the 90-91 had 212mm flywheel and 20 spline clutch.
92-2000 transmissions also work, with a 89-2000 20 spline d-series clutch and respective flywheel, but you will need the hasport cable to hydro conversion kit, which will probably cost more than the transmission.
Old May 16, 2008 | 04:44 AM
Default Re: Transmission compatibility for 89 CRX HF w/ D15B2 (sanimalp)
any 88-91 "CRX" Transmission, or ANY 88-91 Honda Transmission.
Old May 16, 2008 | 05:16 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADAMnQuickRDX &raquo;</TD></TR><TR><TD CLASS="quote">any 88-91 "CRX" Transmission, or ANY 88-91 Honda Transmission.</TD></TR></TABLE> Negative good buddy, not without changing other components as stated in the post above will the 88's work.
Old May 16, 2008 | 09:10 AM
sanimalp's Avatar
$cat /dev/urandom
that would be: Any 88-91 CRX or Civic 2-door hatchback. the 88-91 wagovans are also fair game, but only the 2 wheel drive models.
The important part is what i stated in the previous post, and that is that the flywheel and clutch are what will make using any 88-91 trans possible, because there ARE minor differences in the transmissions through the years, but they are remedied by changing the clutch and flywheel to match the right year of transmission.
adeline
Apr 7, 2011 09:51 AM
hondacivic90zc
Mar 21, 2007 07:19 PM
dannymcar
Feb 18, 2007 07:08 PM
trooper0641
Aug 6, 2005 12:00 PM
denzel
Feb 19, 2005 08:03 AM
